working with database in UTF-8
Jackey Cheung
cheung.jackey at GMAIL.COM
Tue Jun 26 21:34:11 EDT 2007
Well, it shows a bunch of question marks (?) no matter I use arial or big5
fonts. I don't know how to check out the encoding of fonts, and I don't know
which font to use for the case.
If I use the shape (mapinfo) file, which is in Big5 encoding, mapserver can
show the correct characters. I've tried converting the query result to big5
from MySQL:
"SELECT CONVERT(name USING big5) AS name FROM table", and use big5 encoding
and font for the layer, but it doesn't work neither, still only question
marks.
----- Original Message -----
To: "Jackey Cheung" <cheung.jackey at GMAIL.COM>
Sent: Tuesday, June 26, 2007 23:16
Subject: Re: [UMN_MAPSERVER-USERS] working with database in UTF-8
What do you see when you use a unicode Arial, are all characters garbled, a
select few or ? If you have
a font that has big5 encoding AND also unicode that might be the ticket.
Steve
>>> On 6/26/2007 at 3:33 AM, in message
>>> <27FD47F181414813A4276082ED03C0EC at jackey>,
Jackey Cheung <cheung.jackey at GMAIL.COM> wrote:
> I've checked that data in MySQL are loaded correctly with UTF-8 encoding,
> and I can select data out of it with SELECT. However, since I'm using OGR
> to
> connect to MySQL, I'm not sure whether there were any encoding issue here.
> But I'm suspecting that the TTF font I'm using may not correct. I've tried
> some fonts, like Arial, Arial unicode, and another TTF font of Big5
> encoding. But none works. The original encoding of the text is Big5, I've
> converted and loaded them to MySQL as UTF-8, and they show up correct
> inside
> MySQL, what fonts should I use to display them on a map?
> From: "Stephen Woodbridge" <woodbri at SWOODBRIDGE.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Saturday, June 23, 2007 02:45
>> Jackey,
>> I suspect that the font file is not utf8 or the data is already mangled
>> before it gets to mapserver. The mapserver stuff works fine for me with
>> utf-8 data in shapefiles as long as I set the ENCODING 'utf8' in the
>> LABEL. A bigger issue might be:
>> What is the encoding on the source data?
>> what is the encoding on the database?
>> was the data loded correct with respect to the encoding?
>> if you do a select * from table in mysql does the data display correctly?
>> if you slect the records with ogrinfo? to a file or you monitor do they
>> show corectly?
>> There are a WHOLE lot oof steps where things could have broken before it
>> gets to mapserver. You need to validate the data is still good as it
>> comes
>> into mapserver.
>> -Steve W.
>> Steve Lime wrote:
>>> Hmmm... All the encoding parameter does is tell MapServer to convert
>>> from
>>> the supplied encoding to
>>> unicode so I don't think it has any effect. If you already have
>>> unicode/utf-8 strings then this should
>>> just work assuming your font has the right characters.
>>> Does a simple shapefile work?
>>> Steve
>>>>>> On 6/22/2007 at 2:56 AM, in message
>>> <bfb704a40706220056t20220029n82b4ec43aa5e3854 at mail.gmail.com>, Jackey
>>> Cheung
>>>> Greetings!
>>>> I'm trying to setup a mapserver that supports multiple languages with
>>>> MySQL.
>>>> The database uses UTF-8, while the map server use a select statement to
>>>> retrieve records. The layer goes as:
>>>> LAYER
>>>> NAME sr
>>>> STATUS OFF
>>>> TYPE POINT
>>>> CONNECTIONTYPE OGR
>>>> CONNECTION "<OGRVRTDataSource>
>>>> <OGRVRTLayer name='sr'>
>>>> <SrcDataSource>MYSQL:MapSQL,user=root,password=123456,host=localhost,port=3306
>>>> ,tables=POI</SrcDataSource>
>>>> <SrcSQL>SELECT `Name`,
>>>> geom
>>>> FROM `POI` WHERE `ID` = %o%</SrcSQL>
>>>> <GeometryType>wkbPoint</GeometryType>
>>>> </OGRVRTLayer>
>>>> </OGRVRTDataSource>"
>>>> DATA "sr"
>>>> UNITS METERS
>>>> MAXFEATURES 1
>>>> LABELITEM "Name"
>>>> CLASS
>>>> SYMBOL "point"
>>>> MINSIZE 10
>>>> COLOR 250 0 0
>>>> OUTLINECOLOR 0 128 0
>>>> LABEL
>>>> ENCODING "utf-8"
>>>> COLOR 255 0 0
>>>> OUTLINECOLOR 255 255 255
>>>> TYPE TRUETYPE
>>>> FONT arial
>>>> SIZE 8
>>>> ANTIALIAS TRUE
>>>> POSITION UC
>>>> PARTIALS FALSE
>>>> BUFFER 5
>>>> FORCE TRUE
>>>> END
>>>> END
>>>> END
>>>> All Chinese characters are shown as question marks (?) on the map, no
>>>> mater
>>>> using arial or Chinese fonts.
>>>> Any advise?
