CGI Parameter change
Christina
cgackstatter at GMAIL.COM
Thu Mar 1 10:03:05 EST 2007
Hi list,
everytime, when I try to change the cgi parameter by a html document, the
browser wants me to download "mapserv.exe".
I test the itasca demo.
thanks for help!
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is the UMN MapServer demonstration application for
Itasca County located in north central Minnesota."
#WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost/demo_init.html"
WMS_SRS "EPSG:26915"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.png
EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME ctybdpy2
TYPE POLYGON
STATUS DEFAULT
DATA ctybdpy2
CLASSITEM 'cty_name'
CLASS
EXPRESSION 'Itasca'
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
CLASS # every other county in the state
EXPRESSION /./
COLOR 255 255 255
END
METADATA
WMS_TITLE "County Boundary"
WMS_ABSTRACT "Itasca County boundary shapefile. See
http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more
information."
END
END
LAYER
NAME mcd90py2
GROUP cities
TYPE POLYGON
DATA mcd90py2
STATUS OFF
CLASSITEM city_name
CLASS
NAME "Cities & Towns"
EXPRESSION /./
COLOR 255 225 90
TEMPLATE "mcd90py2.html"
END
HEADER "mcd90py2_header.html"
FOOTER "mcd90py2_footer.html"
DUMP TRUE # allow GML export
METADATA
WMS_TITLE "Minor Civil Divisions"
WMS_ABSTRACT "Minor civil divisions for Itasca County. (boundaries
only)"
END
END
LAYER
NAME twprgpy3
TYPE POLYGON
DATA twprgpy3
STATUS OFF
CLASS
SYMBOL 'circle'
SIZE 2
NAME 'Townships'
OUTLINECOLOR 181 181 145
END
METADATA
WMS_TITLE "Township Boundaries"
WMS_ABSTRACT "Pulic Land Survey (PLS) township boundaries for Itasca
County. See http://deli.dnr.state.mn.us/metadata/full/twprgne2.html for more
information."
END
END
LAYER
NAME lakespy2
TYPE POLYGON
STATUS OFF
DATA lakespy2
CLASS
NAME 'Lakes & Rivers'
TEMPLATE "lakespy2.html"
COLOR 49 117 185
END
HEADER "lakespy2_header.html"
FOOTER "lakespy2_footer.html"
TOLERANCE 3
METADATA
WMS_TITLE "Lakes and Rivers"
WMS_ABSTRACT "DLG lake and river polygons for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for more
information."
END
END # lakes
LAYER
NAME dlgstln2
TYPE LINE
STATUS OFF
DATA dlgstln2
CLASS
NAME "Streams"
TEMPLATE "dlgstln2.html"
COLOR 49 117 185
END
HEADER "dlgstln2_header.html"
FOOTER "dlgstln2_footer.html"
TOLERANCE 5
METADATA
WMS_TITLE "Streams"
WMS_ABSTRACT "DLG streams for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for more
information."
END
END # streams
LAYER
NAME ctyrdln3
GROUP roads
MAXSCALE 300000
STATUS OFF
DATA ctyrdln3
TYPE LINE
CLASS
COLOR 0 0 0
END
METADATA
WMS_TITLE "County Roads"
WMS_ABSTRACT "County roads. (lines only) Derived from MNDOT roads
layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more
information."
END
END # county roads
LAYER
NAME ctyrdln3_anno
GROUP roads
MAXSCALE 300000
STATUS OFF
DATA ctyrdln3
TYPE ANNOTATION
LABELITEM "road_name"
CLASS
COLOR 255 255 255
SYMBOL 'symbols/ctyhwy.png'
LABEL
MINFEATURESIZE 40
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
METADATA
WMS_ABSTRACT "County roads. (shields only) Derived from MNDOT roads
information."
END
END # county road annotation
LAYER
NAME majrdln3
GROUP roads
MAXSCALE 600000
STATUS OFF
DATA majrdln3
TYPE LINE
CLASS
NAME "Roads"
COLOR 0 0 0
END
METADATA
WMS_TITLE "Highways"
WMS_ABSTRACT "Highways- state, US and interstate. (lines only) Derived
from MNDOT roads layer, see
information."
END
END # highways
LAYER
NAME majrdln3_anno
GROUP roads
MAXSCALE 600000
STATUS OFF
DATA majrdln3
TYPE ANNOTATION
LABELITEM "road_num"
CLASSITEM "road_class"
CLASS
EXPRESSION "3"
COLOR 0 0 0 # dummy color
SYMBOL 'symbols/sthwy.png'
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION "2"
SYMBOL 'symbols/ushwy.png'
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION "1"
SYMBOL 'symbols/interstate.png'
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 255 255
END
END
METADATA
WMS_ABSTRACT "Highways- state, US and interstate. (shields only)
Derived from MNDOT roads layer, see
information."
END
END # highway annotation
LAYER
NAME airports
TYPE POINT
DATA airports
STATUS OFF
CLASS
NAME 'Airports'
COLOR 128 255 164
SYMBOL 'circle'
SIZE 7
TEMPLATE "airports.html"
END
HEADER "airports_header.html"
FOOTER "airports_footer.html"
TOLERANCE 5
METADATA
WMS_TITLE "Airports"
WMS_ABSTRACT "Airport runways for Itasca County."
END
END
LAYER
#NAME mcd90py2_anno
NAME cities
TYPE ANNOTATION
DATA mcd90py2
STATUS OFF
LABELITEM "city_name"
CLASSITEM "city_name"
LABELMAXSCALE 500000
CLASS
EXPRESSION /./
COLOR -1 -1 -1
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER 2
END
END
METADATA
WMS_ABSTRACT "Minor civil divisions for Itasca County. (annotation
only)"
END
END
END # Map File
<html>
<head><title>MapServer Demo Interface</title></head>
<body bgcolor=#FFFFFF>
<center><h1>MapServer Demo Interface</h1></center>
<hr>
<form method=GET action="D:\Programme\Apache
Group\Apache2\cgi-bin\mapserv.exe?map=D:\htdocs\demo.map">
<center>
<table border=0 cellspacing=0 cellpadding=4 bgcolor="#000000">
<tr>
<td valign="top" align=center>
<table cellpadding="0" cellspacing="0" border="0">
<tr><td colspan="2"><INPUT NAME="img" TYPE="image" SRC="[img]" width=600
height=600 border=0></td></tr>
<tr>
<td> <font size=-1 face="arial,helvetica"
color="#FFFFFF"><b>Powered by MapServer</b></font></td>
<td align="right"><img src="[scalebar]"></td>
</tr>
</table>
</td>
<td valign="top" bgcolor=#ffffff>
<table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
<tr><td>
<center><input type="submit" value="Refresh/Query"></center>
<p>
<input type="radio" name="mode" value="browse" checked> <b>Browse
map</b><br>
<input type="radio" name="mode" value="query"> <b>Query
feature</b><br>
<input type="radio" name="mode" value="nquery"> <b>Query multiple
features</b>
<hr>
<p>
<b>Select Layers to Display: </b><br>
<select multiple name="layer" size=3>
<option value="airports" [airports_select]> Airports
<option value="cities" [cities_select]> Cities
<option value="lakespy2" [lakespy2_select]> Lakes & Rivers
<option value="dlgstln2" [dlgstln2_select]> Streams
<option value="roads" [roads_select]> Roads
<option value="twprgpy3" [twprgpy3_select]> Townships
</select>
<p>
Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
Zoom Out <input type=radio name=zoomdir value=-1 [zoomdir_-1_check]>
<p>
Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
<p>
<font size=+1><b>Legend</b></font><br><hr>
<img src="[legend]"><hr>
<p>
<center><INPUT NAME="ref" TYPE="image" SRC="[ref]"
border="0"></center>
</td></tr></table>
</td></tr>
</table>
</center>
<input type="hidden" name="imgxy" value="299.5 299.5">
<!-- <input type="hidden" name="imgext" value="[mapext]"> -->
<input type="hidden" name="map" value="demo.map">
<input type="hidden" name="layer" value="airports">
<input type="hidden" name="layer" value="dlgstln2">
<input type="hidden" name="layer" value="lakespy2">
<input type="hidden" name="layer" value="mcd90py2">
<input type="hidden" name="layer" value="twprgpy3">
<input type="hidden" name="layer" value="ctyrdln3">
<input type="hidden" name="zoomsize" value=2>
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="program" value=\cgi-bin\mapserv.exe">
<input type="hidden" name="map_web_imagepath" value="/tmp/">
<input type="hidden" name="map_web_imageurl" value="/tmp/">
</form>
<p><hr><p>
</body></html>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070301/6b81f1a7/attachment.html
