MapServer 4.10 with DSO PHP5
Guillaume Sueur guillaume.sueur at GEOSIGNAL.FR
Thu Mar 1 10:16:52 EST 2007
great ! it works perfectly now. thanks for your help Daniel.
Daniel Morissette a écrit :
> The issue with REGEX was solved a few releases ago using some wrappers,
> so it should not matter any more which version of REGEX you use to build
> PHP and MapScript.
> Daniel
> Guillaume Sueur wrote:
>> that can be an interesting clue. Do you know if the regex trick is
>> still  mandatory ?
>>> That could be caused by conflicting versions of GD, i.e. Your PHP has
>>> --with-gd which will probably trigger the use of its built-in copy of
>>> GD, and your php_mapscript.so is built with the system GD.
>>> I'd suggest that you try rebuilding your PHP using the system GD and
>>> see if that helps. If GD is unstalled under /usr/local then use
>>> --with-gd=/usr/local
>>> Daniel
>>>> Hi list,
>>>> I was wondering if MapScript 4.10 could be build with PHP5 as Apache
>>>> DSO. I've done several attempts, without success. The build goes
>>>> fine, but invoking the draw method on a map object causes a
>>>> segmentation fault.
>>>> I've tried the "regex hack" on the php configure, to force php to be
>>>> build with system regex.
>>>> The option with-apxs on mapserver configure fires a message saying
>>>> in can't work that way. I can accept that, but why are people saying
>>>> it works fine for them on the net ?
>>>> So, if you had a clue, and some configure options and workarounds, I
>>>> would really appreciate.
>>>> Here are my php configure options (the use of regex=system is forced
>>>> in the configure script):
>>>> './configure' '--prefix=/usr/local/apache2/'
>>>> '--with-apxs2=/usr/local/apache2/bin/apxs'
>>>> '--with-config-file-path=/usr/local/apache2/php'
>>>> '--with-regex=system' '--with-jpeg-dir=/usr' '--with-png-dir=/usr'
>>>> '--with-zlib' '--with-gd' '--with-freetype-dir=/usr/local/'
>>>> '--enable-dbase' '--with-pdflib' '--enable-gd-native-ttf'
>>>> Thanks
