MapServer 4.10 with DSO PHP5 -> GD issues
Guillaume Sueur
guillaume.sueur at GEOSIGNAL.FR
Fri Mar 2 03:14:24 EST 2007
One more thing : using the system gd library works well, but some gd
functions (imagerotate or imagelayereffect for example) requires php to
be build against embedded version of gd.
So, is there a way to build mapserver against php version of gd, or to
find the source of it to be able to build it as the system lib too ?
Thanks
Guillaume Sueur a écrit :
> great ! it works perfectly now. thanks for your help Daniel.
> Daniel Morissette a écrit :
>> The issue with REGEX was solved a few releases ago using some
>> wrappers, so it should not matter any more which version of REGEX you
>> use to build PHP and MapScript.
>> Daniel
>> Guillaume Sueur wrote:
>>> that can be an interesting clue. Do you know if the regex trick is
>>> still mandatory ?
>>>> That could be caused by conflicting versions of GD, i.e. Your PHP
>>>> has --with-gd which will probably trigger the use of its built-in
>>>> copy of GD, and your php_mapscript.so is built with the system GD.
>>>> I'd suggest that you try rebuilding your PHP using the system GD and
>>>> see if that helps. If GD is unstalled under /usr/local then use
>>>> --with-gd=/usr/local
>>>> Daniel
>>>>> Hi list,
>>>>> I was wondering if MapScript 4.10 could be build with PHP5 as
>>>>> Apache DSO. I've done several attempts, without success. The build
>>>>> goes fine, but invoking the draw method on a map object causes a
>>>>> segmentation fault.
>>>>> I've tried the "regex hack" on the php configure, to force php to
>>>>> be build with system regex.
>>>>> The option with-apxs on mapserver configure fires a message saying
>>>>> in can't work that way. I can accept that, but why are people
>>>>> saying it works fine for them on the net ?
>>>>> So, if you had a clue, and some configure options and workarounds,
>>>>> I would really appreciate.
>>>>> Here are my php configure options (the use of regex=system is
>>>>> forced in the configure script):
>>>>> './configure' '--prefix=/usr/local/apache2/'
>>>>> '--with-apxs2=/usr/local/apache2/bin/apxs'
>>>>> '--with-config-file-path=/usr/local/apache2/php'
>>>>> '--with-regex=system' '--with-jpeg-dir=/usr' '--with-png-dir=/usr'
>>>>> '--with-zlib' '--with-gd' '--with-freetype-dir=/usr/local/'
>>>>> '--enable-dbase' '--with-pdflib' '--enable-gd-native-ttf'
>>>>> Thanks
