mapserver segfaults on x68_64 intel xeon
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Fri Mar 2 06:10:08 EST 2007
Can you send the distint values upon which the style info is built?
I wouldn't be surprised if one of those had non-ascii characters!
Try to remove non ascii-chars and report if that solved the issue.
Umberto
On 3/2/07, Alessandro Pasotti <ale.pas at tiscali.it> wrote:
> Il 11:11, venerdì 2 marzo 2007, Umberto Nicoletti ha scritto:
> > Send us the stack trace (run the backtrace command from gdb) so that
> > we can see what mapserver is doing when it crashed and report the
> > configure flags.
> Here is the configure command:
> ./configure \
> --libdir=/usr/lib64 \
> --with-wfs \
> --with-gd=/usr/lib64 \
> --with-wfsclient \
> --with-wmsclient \
> --with-proj=/usr/local/lib \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-ogr=/usr/local/bin/gdal-config \
> --with-php=/usr/local/include/php \
> --with-httpd=/usr/sbin/httpd2 \
> --prefix=/usr/local
> Here is the backtrace:
> linux:~/webgis/mapserver-4.10.1 # gdb ./shp2img
> GNU gdb 6.3
> Copyright 2004 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you are
> welcome to change it and/or distribute copies of it under certain conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show warranty" for details.
> This GDB was configured as "x86_64-suse-linux"...Using host libthread_db
> library "/lib64/tls/libthread_db.so.1".
> (gdb) set args -all_debug 9 -m /srv/www/htdocs_ssl/maps/appalto_26.map
> (gdb) run
> Starting program: /root/webgis/mapserver-4.10.1/shp2img -all_debug
> [Thread debugging using libthread_db enabled]
> [New Thread 46912537641952 (LWP 24490)]
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 46912537641952 (LWP 24490)]
> 0x00002aaaac693e40 in rawmemchr () from /lib64/tls/libc.so.6
> (gdb) backtrace
> #0 0x00002aaaac693e40 in rawmemchr () from /lib64/tls/libc.so.6
> #1 0x00002aaaac6882ba in _IO_str_init_static_internal ()
> #2 0x00002aaaac67dd95 in vsscanf () from /lib64/tls/libc.so.6
> #3 0x00002aaaac679488 in sscanf () from /lib64/tls/libc.so.6
> #4 0x00002aaaab4fd7fc in OGRStyleTool::GetRGBFromString ()
> from /usr/local/lib/libgdal.so.1
> #5 0x0000000000423ee3 in msOGRLayerGetAutoStyle ()
> #6 0x000000000042a804 in msDrawVectorLayer ()
> #7 0x000000000042a959 in msDrawLayer ()
> #8 0x000000000042b750 in msDrawMap ()
> #9 0x000000000040a40c in main ()
> Thanks for helping.
> Alessandro Pasotti
> itOpen - "Open Solutions for the Net Age"
> w3: www.itopen.it
> Linux User# 167502
