mapserver segfaults on x68_64 intel xeon
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Fri Mar 2 09:58:49 EST 2007
Recompile mapserver with --enable-debug and then use gdb to discover
which string is causing the crash when passed to
OGRStyleTool::GetRGBFromString.
Umberto
On 3/2/07, Alessandro Pasotti <ale.pas at tiscali.it> wrote:
> Il 12:10, venerdì 2 marzo 2007, Umberto Nicoletti ha scritto:
> > Can you send the distint values upon which the style info is built?
> STYLEITEM "AUTO"
> it's a mapinfo tab
> > I wouldn't be surprised if one of those ha
> > d non-ascii characters!
> Well, this doesn't seems to be the case, it segafults even when there are only
> ASCII characters.
> If I comment #STYLEITEM "AUTO" ms doesn't segfault.
> The problem is definitely with STYLEITEM "AUTO", but as I said in my other
> post, this works fine on my testing machine.
> Thanks
> Alessandro Pasotti
> itOpen - "Open Solutions for the Net Age"
> w3: www.itopen.it
> Linux User# 167502
