wms.jpl.nasa.gov renders on LINUX but not in the MS4W install
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Fri Mar 2 14:49:39 EST 2007
I responded to this on the MS4W list
(http://lists.maptools.org/pipermail/ms4w-users/2007-March/000741.html)
jeff
Andrew Parker wrote:
> I am trying to add the modis and global_mosaic layers from
> http://wms.jpl.nasa.gov to the map in my MS4W install (on Windows XP and
> Windows Server2003). WMS layers render from terraservice.net with no
> problems. The code in the mapfile works with the LINUX test box.
> Does anyone have a reason or solution? Be easy on me as I am new to
> Mapserver. Below is my mapfile code.
> Thanks in advances for any help.
> Andrew.
> # Start of map file
> # Sample map file for a chameleon app.
> NAME DEMO
> STATUS ON
> SIZE 400 300
> SYMBOLSET ../etc/symbols.sym
> EXTENT -109.1 31.26 -102.89 37.09
> UNITS DD
> PROJECTION
> "init=epsg:4326"
> END
> SHAPEPATH "../data"
> IMAGECOLOR 25 25 112
> FONTSET ../etc/fonts.txt
> TRANSPARENT FALSE
> # IMAGETYPE - set to PNG24 in /congif/chameleon.xml
> # Start of web interface definition
> WEB
> #MINSCALE 2000000
> #MAXSCALE 50000000
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> # of the drive where the .MAP file resides.
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> # LOG "/tmp/gmap.log"
> METADATA
> END
> END
> # Start of reference map
> REFERENCE
> IMAGE images/ref_msone.jpg
> EXTENT -126.12 23.27 -66.14 50.15
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> SIZE 120 90
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> IMAGECOLOR 255 255 255
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> SIZE 150 5
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS Miles
> INTERVALS 5
> STATUS ON
> END
> QUERYMAP
> STYLE HILITE
> COLOR 255 0 0
> END
> # Symbol for drawing fat lines
> SYMBOL
> NAME "BigLine"
> TYPE ELLIPSE
> POINTS 1 1 END
> END
> # Symbol for drawing dashed lines
> SYMBOL
> NAME "DashedLine"
> TYPE ELLIPSE
> POINTS 1 1 END
> STYLE 10 10 END
> END
> # Symbol for drawing spots
> SYMBOL
> NAME "Circle"
> FILLED true
> TYPE ellipse
> POINTS 1 1 END
> END
> # Country layer
> LAYER
> NAME "Countries"
> STATUS on
> TYPE polygon
> DATA "countries"
> UNITS dd
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> # A template defined at the class level is used to
> # display the results for each reponse to a query. If a
> # query results in N hits, then the template will be used
> # N times. To be queriable a layer must specify a CLASS
> # level template.
> TEMPLATE "/ms4w/apps/msone/htdocs/msone_countries_query.html"
> NAME "USA"
> EXPRESSION ('[COUNTRY]' eq 'US')
> STYLE
> COLOR 238 232 170
> END
> END # end class
> CLASS
> # level template.
> NAME "OTHER"
> EXPRESSION ('[COUNTRY]' ne 'US')
> STYLE
> COLOR 205 190 112
> END
> END # end class
> END # end layer
> # Line layer for Country boundaries
> LAYER
> UNITS dd
> PROJECTION
> "init=epsg:4326"
> END
> NAME "Boundaries"
> STATUS on
> TYPE line
> DATA "countries"
> CLASS
> STYLE
> COLOR 0 0 0
> END
> END # end class
> END # end layer
> # USGS_topo
> LAYER
> NAME "Terraserver_DRG"
> STATUS off
> TYPE RASTER
> CONNECTIONTYPE WMS
> CONNECTION "http://terraservice.net/OgcMap.ashx?";
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_title" "Digital Raster Graphic"
> "wms_name" "DRG"
> "wms_server_version" "1.1.1"
> "wms_format" "image/jpeg"
> "wms_layers" "drg"
> "wms_group_title" "background"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> # ******************** Orthophoto ********************
> LAYER
> NAME "TerraServer_Orthophoto"
> STATUS off
> TYPE RASTER
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "Orthophoto"
> "wms_name" "DOQ"
> "wms_layers" "drg"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> # ******************** Nexrad Radar ********************
> LAYER
> NAME Nexrad_RADAR
> STATUS OFF
> GROUP "Background"
> TYPE RASTER
> CONNECTIONTYPE WMS
> CONNECTION "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?";
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_name" "nexrad-n0r-m45m"
> "wms_style" ""
> "wms_title" "NEXRAD"
> END
> END
> # ******************** MODIS derived blue marble image ********************
> LAYER
> NAME Blue_Marble
> STATUS on
> PROJECTION
> "init=epsg:4326"
> END
> TYPE RASTER
> OFFSITE 0 0 0
> CONNECTIONTYPE WMS
> CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?";
> METADATA
> "wms_name" "modis,global_mosaic"
> "wms_styles" ""
> "wms_title" "BlueMarble"
> END
> END
> # State boundaries layer - polygon (for shading)
> LAYER
> NAME "states_poly"
> DATA "statesp020"
> UNITS dd
> PROJECTION
> "init=epsg:4326"
> END
> STATUS off
> TYPE polygon
> LABELCACHE on
> LABELITEM "STATE"
> CLASS
> STYLE
> # COLOR 238 232 170
> END
> END
> END
> # State boundaries layer - line (for fat boundary)
> LAYER
> NAME "states"
> DATA "statesp020"
> UNITS dd
> PROJECTION
> "init=epsg:4326"
> END
> STATUS off
> TYPE line
> LABELCACHE on
> LABELITEM "STATE"
> CLASS
> NAME "State Line"
> STYLE
> SYMBOL "BigLine"
> SIZE 2
> COLOR 0 0 0
> END
> END
> END
> # Road layer - interstates only at large scale
> LAYER
> NAME "interstate1"
> GROUP "roads"
> DATA "roadtrl020"
> STATUS off
> TYPE line
> UNITS dd
> PROJECTION
> "init=epsg:4326"
> END
> LABELCACHE on
> LABELITEM "NAME"
> CLASSITEM "FEATURE"
> MINSCALE 7500001
> CLASS
> NAME "Interstate Hwy"
> EXPRESSION /Limited Access*/
> STYLE
> SYMBOL "BigLine"
> SIZE 1
> COLOR 0 0 0
> END
> LABEL
> TYPE truetype
> FONT "arial"
> SIZE 8
> OUTLINECOLOR 255 255 255
> COLOR 0 0 0
> MINDISTANCE 200
> POSITION auto
> ANGLE auto
> MINFEATURESIZE 50
> END
> END
> END
> # ROC Sites
> LAYER
> NAME "ROCsites"
> STATUS off
> UNITS dd
> PROJECTION
> "init=epsg:4326"
> END
> TYPE point
> DATA "ROCsites"
> MAXSCALE 1200000
> LABELITEM "SITE_NAME"
> CLASS
> NAME "ROC Sites"
> STYLE
> SYMBOL "Circle"
> SIZE 9
> COLOR 255 127 0 #coral
> END
> LABEL
> TYPE truetype # use truetype font
> FONT "arialbd" # use arial bold
> SIZE 7 # use 8 point size
> COLOR 255 127 0 # color text coral
> BACKGROUNDCOLOR 255 255 255 # render text on white bg
> MINDISTANCE 50 # labels > 50 pixels apart
> POSITION auto # center labels below feature
> ANTIALIAS true # antialias the text
> END # end label
> END # end class
> END # end layer
> # ROC Monitoring Wells
> LAYER
> NAME "ROCmw"
> STATUS off
> UNITS dd
> TYPE point
> DATA "ROCmw"
> LABELITEM "Well_Name" # labels use value in column "NAME"
> LABELCACHE on
> LABELMAXSCALE 1200000
> MAXSCALE 1200000
> CLASS
> NAME "ROC MWs"
> STYLE
> SYMBOL "Circle"
> SIZE 9
> COLOR 0 0 205 #Medium Blue
> END
> LABEL
> COLOR 0 0 205 # color text coral
> END # end label
> END # end class
> END # end layer
> END # Map File
