Problems with Mapserver4.10.1--GD--Fedora Core 6 (espanol -
english)
Guillaume Sueur
guillaume.sueur at GEOSIGNAL.FR
Sun Mar 4 05:10:46 EST 2007
Yes, the error can come from that too. You should check that point. Can
you send your configure options ?
why don't you uninstall all rpms and build all from sources ? it's often
easier !
Guillaume
Adriano Torres a écrit :
> Gregor Mosheh escribió:
>> I've had the worst time with Fedora, in that it's often missing header
>> files. In the case of GD, it's missing the gd.h and other header files.
>> Sigh.
>> What I've resorted to in the past is to download the GD source for the GD
>> version I have (rpm -qa | grep gd) and then manually install gd.h into
>> /usr/include or wherever.
> Hi everybody
> Thanks Gregor for four answer... I tried to install manually but ./configure
> doesn't work yet :(
> The mapserver configure said: "configure: error: Could not find gd.h or
> libgd.a/libgd.so in /usr/local. Make sure GD 2.0.16 or higher is compiled
> before calling configure. You may also get this error if you didn't specify
> the appropriate location for one of GD's dependencies (freetype, libpng,
> libjpeg or libiconv)"
> I have freetype, libpng, libjpeg and libiconv properly installed (I believe it):
> # rpm -qa | grep gd
> sysklogd-1.4.1-41.fc6
> gd-2.0.33-10.fc6
> gdb-6.5-15.fc6
> gdbm-1.8.0-26.2.1
> php-gd-5.1.6-3.4.fc6
> gd-devel-2.0.33-10.fc6
> gdm-2.16.5-1.fc6
> libgdiplus-1.1.17-1.fc6
> gdbm-devel-1.8.0-26.2.1
> What mean that "You may also get this error if you didn't specify the
> appropriate location for one of GD's dependencies"??? May the error be this?
> I dont know what do :(
> Thanks
> Adriano
> Saludos a la comunidad de habla hispana.
