Can I use 1 UMN-Service to deliver WMS-Requests in different geodetic dates???
Christian Mairamhof Christian.Mairamhof at KTN.GV.AT
Tue Mar 6 04:42:06 EST 2007
Our layer is defined in a local CRS like 31285.
Also the TOWGS84 parameter is set  for correct placement of data in CRS
4326 (WGS84).
Now the placement in 4326 is correct and false in 31286, if I skip the
TOWGS84 parameter i have the vice versa effect.
Is there a way that the TOWGS84 transformation is only used when it is
needed?
Here our layer/projection section:
 PROJECTION
  "proj=tmerc"
  "ellps=bessel"
  "lat_0=0"
  "lon_0=13.33333333333333"
  "k=1.000000"
  "x_0=450000"
  "y_0=-5000000"
  "units=m"
  "towgs84=577.326,90.129,463.919,5.1365988,1.4742,5.2970436,2.4232"
 END
or
 PROJECTION
  "init=EPSG:31285"
 END
best regards,
Christian
_______________________________
AMT DER KÄRNTNER LANDEREGIERUNG
Abt. 18 - Wasserwirtschaft / IKT
Ing. Christian MAIRAMHOF
Völkermarkter Ring 29 , A-9020 Klagenfurt
Tel +43 (0) 463 536-31826
e-mail: christian.mairamhof at ktn.gv.at
homepage: wasser.ktn.gv.at
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070306/96f842f8/attachment.html
