Text Editor
Sebastian Schmitz sebastian.schmitz at WHEREGROUP.COM
Tue Mar 6 05:58:19 EST 2007
if you want easy mapfile creation you may also want to have a look at
MapStorer, which is a web-based and database-supported tool for creating
MapServer mapfiles. It lets you generate mapfiles within minutes and you
can combine layers from several mapfiles with each other
(http://www.mapstorer.org).
Just a hint.
Cheers
Sebastian
Benedikt Rothe schrieb:
> http://mapserver.gis.umn.edu/docs/link/textpad-syntax
> or
> http://www.textpad.com/add-ons/files/syntax/map_40.zip
> UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
> 06.03.2007 10:11:34:
> > Dear All,
> > i would like to know that is there any Text Editor that i can use to
> create my .MEP files with it? What i would like to know is anything
> like TextPad or Visual Studio .net Html editor so that i can type
> easily with formatting.
> > Kindest Regards,
> > Jandost Khoso
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
mailto:sebastian.schmitz at wheregroup.com
http://www.wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
