Mapinfo Seamless Vector tables in mapserver
mikiet
mike.talbutt at DOTTEDEYES.COM
Tue Mar 6 09:39:44 EST 2007
No dice eh ?, I have alittle more information in case it sheds some light on
whats going on.
I have set up the seamless table using mapinfo pro's seamless manager tool,
specifying full path. I noticed that if I do an ogrinfo on my table it works
fine
C:\Tomcat5\webapps\rmxnyf\mapbase>ogrinfo test.tab
Had to open data source read-only.
INFO: Open of `test.tab'
using driver `MapInfo File' successful.
1: Area_Mosaic (Line String)
However when i specify the full path of the tab file I get an error
C:\Tomcat5\webapps\rmxnyf\mapbase\test
.TAB
FAILURE:
Unable to open datasource `C:\Tomcat5\webapps\rmxnyf\mapbase\test.TAB' with
the
following drivers.
-> OCI
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> PGeo
-> PostgreSQL
-> MySQL
When I do this test on a normal (non seamless) tab file ogrinfo works fine
regardless of whether or not I specify the full name.
Is this a clue as to where it's all going wrong ?.
mikiet wrote:
> Hi all,
> I have a seamless mapinfo table that points to several mapinfo tab files
> containing vector data. I would like to be able to use this seamless table
> in my mapserver map file. I read that mapserver should be able to handle
> the seamless table
> (http://www2.dmsolutions.ca/msapps/ro_demo/demo_init.html), however when I
> point to my seamless table I get the following error message
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `C:\MapBase\Topo_Area_Seamless.TAB'. File not found or unsupported format.
> I have done simillar things with mapinfo seamless tables containing raster
> images by using the gdaltindex utility to create shp files, and that
> worked well, do I need to use a simillar tecnique for seamless tables
> containg vector data
> thanks in advance for the advice
> Mike.
View this message in context: http://www.nabble.com/Mapinfo-Seamless-Vector-tables-in-mapserver-tf3349859.html#a9332637
Sent from the Mapserver - User mailing list archive at Nabble.com.
