WMS/WFS and (yearly) time-dependent data
Peter schrock
thesl at YAHOO.COM
Thu Mar 8 10:50:20 EST 2007
Hello, I am having difficulties to make WMS time series work.
I am using mapserver 4.10.0. I tested point data with time dimension, it
worked. I tested tiled polygons, it worked.
But I cannot get polygon shapefile work for time series WMS
The part of my mapfile is:
# Polygon layers, identitical polygon shapefiles, one shapefile for one
year. tile index shapefile was created using tile4ms.exe
# Test method 1: everything in one layer object
LAYER
NAME "timemap"
TYPE RASTER
STATUS ON
METADATA
"wms_title" "timemap"
"wms_timeformat" "YYYYMMDD"
"wms_timeextent" "20021130/20061130"
"wms_timeitem" "DATETIME"
"wms_timedefault" "20021130"
"wms_srs" "EPSG:4326"
END
TILEINDEX "index1.shp"
TILEITEM "Location"
CLASSITEM "color_code"
CLASS
NAME "TYPE 1"
EXPRESSION ([color_code]==1)
COLOR 220 120 130
OUTLINECOLOR 150 150 150
END
CLASS
NAME "TYPE 2"
EXPRESSION ([color_code]==2)
COLOR 255 255 155
END
CLASS
NAME "TYPE 3"
EXPRESSION ([color_code]==0)
COLOR 200 200 200
OUTLINECOLOR 100 100 100
END
END # one layer object method
# Test method 2: seperate tileindex layer and data layer
LAYER
NAME "mylayer"
STATUS ON
TYPE RASTER
TILEINDEX "index1"
TILEITEM "Location"
PROJECTION
"init=epsg:4326"
END
METADATA
"DESCRIPTION" "mylayer"
"wms_title" "mylayer"
"WMS_SRS" "epsg:4326"
"wms_timedefault" "20030210"
END
SIZEUNITS PIXELS
CLASS
NAME "TYPE 1"
COLOR 220 120 130
END
CLASS
NAME "TYPE 2"
COLOR 255 255 155
END
CLASS
NAME "TYPE 3"
COLOR 200 200 200
END
END
LAYER
NAME "tidx"
TYPE TILEINDEX
STATUS ON
DATA index1
FILTERITEM 'DATETIME'
FILTER '%DATETIME%'
END # tile layer
The error message is:
msDrawMap(): Image handling error. Failed to draw layer named 'timemap'.
msDrawRaster(): Image handling error. Unrecognized or unsupported image
format drawEPP(): Image handling error. EPPL7 support is not available.
Did mapserver support WMS time series using polygon shapefile?
Yewondwossen Assefa wrote:
> If your are serving layers as wms you could do soemthing like this :
> - define a tileindex layer example:
> LAYER
> NAME "mylayer"
> STATUS ON
> # TYPE POLYGON
> TYPE RASTER
> METADATA
> "wms_timeitem" "time"
> "wms_timeextent" "1970/2006"
> END
> SIZEUNITS PIXELS
> TILEINDEX "tile_file"
> TILEITEM "location"
> - have a tile index that has at least 2 field (localtion for the
> files, and a time field) :
> location time
> mypath/myfile 2005
> - doing a request of Getmap : something like
> GetMap&Version=1.1.1&LAYERS=mylayer&Time=2005
> Not sure if that fits your model.
> Best Regards
View this message in context: http://www.nabble.com/Re%3A-WMS-WFS-and-%28yearly%29-time-dependent-data-tf3266243.html#a9374208
Sent from the Mapserver - User mailing list archive at Nabble.com.
