self overlaped linestring not drawed
Frank Warmerdam
warmerdam at POBOX.COM
Thu Mar 8 17:55:54 EST 2007
Rodrigo Martín LÓPEZ GREGORIO wrote:
> Hi everybody.
> I have a linestring layer with bus routes. Some buses pass two times
> over the same zone, so two different segments of the linestring overlaps
> (same start and end point). The strange thing is that mapserver
> sometimes dont show this segments even for the same zoom level ( i.e.
> when i pan the map sometimes the segments shows and somtimes no). The
> rest of the linestring are draw perfectly.
> Obviously an easy workaround is move the segments so its don't overlaps
> one each other. But I think that it is quite strange. May be it could be
> a bug (I'm using ms4w). I dont think it could be a problem with my
> mapfile cause sometimes this segments are drawed an somtimes not.
Rodrigo,
If you can boil this down to a simple mapfile, and a simple shapefile
and a command to render the map with shp2img that demonstrates the problem,
then I think you should submit this as a bug report. I can't think of any
reason self-intersection should be a problem for a linestring.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
