Mapserver, PostGIS and case
Richard Duivenvoorde
rdmailings at DUIF.NET
Fri Mar 9 13:39:42 EST 2007
Hi List,
I've found some other postings about it. But think I've encountered a
bug or otherwise some non-logical behaviour.
I changed a PostGIS table with a geomety column name the_geom to LOCATIE.
CREATE TABLE "POINTLAYER"
"LOCATIE" geometry NOT NULL,
After some fiddling (reading the postgresql help on 'Identifiers and Key
Words' and the mapserver list etc) around I was able to show a MAP using
the following DATA string in the mapfile:
DATA '"LOCATIE" FROM (select *, oid from "public"."POINTLAYER") as
foo using unique oid using SRID=28992'
But the featureinfo requests keep failing then with an mapserver error:
Fri Mar 09 19:23:53 2007 - msPOSTGISLayerGetItems(): Query error.
msPOSTGISLayerGetItems: tried to find the geometry column in the results
from the database, but couldnt find it. Is it miss-capitialized?
'"LOCATIE"'
After changing the column name LOCATIE to locatie:
locatie geometry NOT NULL,
and datastring:
DATA '"locatie" FROM (select *, oid from "public"."POINTLAYER") as foo
produces a map, but NO featureresponse, but errors:
'"locatie"'
changing the DATA-string to:
DATA 'locatie FROM (select *, oid from "public"."POINTLAYER") as foo
is producing both a map and a featureinfo response :-)
It looks like there is some fiddling around with double quotes in the
mapserver code, but it looks like the mapping part and featureinfo part
are working in different ways with quotes?
So, it's working for me now, but I thought that it may be helpfull to
others to read this. Should I post a bug for this?
Richard
