Simple configuration PostgreSQL/MapServer/Openlayers
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Sun Mar 11 08:07:45 EDT 2007
Hi Andy,
first of all, EPSG is a code number list, so use:
EPSG:27700 instead of EPSG:BNG.
Also advertize this in your WMS_SRS for all layers and the MAP METADATA
section. Change your openlayers config for this as well ofcourse.
Use projection blocks for all LAYERs and the MAP (this is the native
projection of your data):
PROJECTION
"init=epsg:27700"
END
If you want Mapserver WMS to be able to reproject your data, then advertize
more EPSG code in the WMS_SRS, for instance EPSG:4326 if you want to add
WGS84 support.
Let us know if you get it to work.
Best regards,
Bart
Andy Fo schreef:
> Hi,
> Is there anybody out there that can help me with this very simple
> configuration?
> Im new to WMS and Im learning about it right now. Im not completely new
> to programming though; I have experience in C, PL/SQL, MapBasic and a bit
> of JavaScript and HTML. Im into GIS and used Oracle Spatial with MapInfo
> software at work. I only now started to appreciate open source.
> I decided to go onto practice straight away and opted for the following
> configuration:
> PostgreSQL/PostGIS (this is an excellent db and the documentation is
> impressive!)
> MapServer for rendering images and
> Openlayers as a simple way to interact with the map/information.
> Everything installed locally.
> All I need is some sort of Hello World style example, some sort of
> launch pad where I can add or change bit and pieces as I learn. Seeing
> something actually working would give me the confidence to going through
> all the details.
> It should work with this configuration and I would be really grateful if
> someone could help me with this.
> I have loaded some vector data into Postgres, some polylines (or
> linestrings) representing road network. This is referenced to British
> National Grid (BNG) srid: 27700. The table has been spatially indexed.
> Heres where I can smell some trouble.
> MapServer successfully outputs a png image with the following map file:
> MAP
> IMAGETYPE PNG
> EXTENT 525300 179800 536700 187600
> SIZE 800 600
> SHAPEPATH "/ms4w/apps/TestMaps/FirstTest"
> IMAGECOLOR 192 192 192
> UNITS METERS
> LAYER
> CONNECTIONTYPE postgis
> NAME "tlrn_network"
> CONNECTION "user=??? password=??? dbname=mapping host=localhost"
> DATA "wkb_geometry FROM net"
> STATUS ON
> TYPE LINE
> CLASS
> COLOR 0 0 0
> END
> METADATA
> "WMS_SRS" "EPSG:BNG"
> END
> PROJECTION
> "init=epsg:27700"
> END
> END
> END
> I tested this firefox and the following URL:
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/TestMaps/FirstTest/tlrn.map&layer=tlrn_network&mode=map
> So far so good, but heres the trouble:
> <html>
> <head>
> <script src="http://openlayers.org/api/2/OpenLayers.js"></script>
> </head>
> <body>
> <div style="width:100%; height:100%" id="map"></div>
> <script defer="defer" type="text/javascript">
> var mymap = new OpenLayers.Map('map');
> var mylayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
> "http://localhost/cgi-bin/mapserv.exe?",{layers:
> 'tlrn_network',map:'/ms4w/apps/TestMaps/FirstTest/tlrn.map'},{projection:
> "EPSG:BNG"});
> mymap.addLayer(mylayer);
> mymap.zoomToMaxExtent();
> </script>
> </body>
> </html>
> It just doesnt work. Openlayers kind of attempt to display the image, it
> shows the correct background color. However, instead of my road network,
> it shows the following error message on each tile:
> MsWMSLoadGetMapParams(): WMS server error. Cannot set new SRS on a map
> that doesnt have any projection set. Please make sure your mapfile has a
> projection defined at the top level.
> Well, obviously my map file has no defined projection at top level. It is
> only defined at the layers level (and probably wrongly). Whenever I
> attempt to do at the Map top level it seems that things get only worse or
> no change at all.
> When I get rid of the metadata, for example
> # METADATA
> # "WMS_SRS" "EPSG:BNG"
> # END
> the message changes to:
> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS must
> be valid for all requested layers.
> Im stuck! As I said all I need is something that works and I can use as a
> base. Ill go away and practice with all this without harassing the entire
> community (well, for a while at least!).
> Many thanks
> Andy
OSGIS, Open Source GIS
http://www.osgis.nl
