ArcSDE and SLD WMS ( attribute queries)
Chris Tweedie
chrislist at NARX.NET
Tue Mar 13 07:38:39 EDT 2007
Bart, i may be grasping at straws here ... but have you had a look at CVS lately? Howard has checked in a lot of new stuff which solved some of our prior issues with SDE. I'd be interested to hear whether your issue remains as we are intending to use SLD's on the SDE layers as well.
Chris Tweedie
On Tue, 13 Mar 2007 10:29:06 +0100, "Bart van den Eijnden (OSGIS)" <bartvde at OSGIS.NL> wrote:
> Hi list,
> using Mapserver on ArcSDE and trying to apply an SLD with a Filter I run
> into internal server errors all the time after about 30 seconds.
> My reasoning is that this is since the query-by-id mechanism will query
> ArcSDE for each item of the resultset and this just won't work.
> So can I safely conclude Mapserver on ArcSDE won't work well for
> non-spatial
> queries?
> I am using FastCGI already. Using cgi crashes as well, but after a longer
> period of waiting time (minutes).
> Best regards,
> Bart
Chris Tweedie
