No drawing of certain polygon rings stroed in Oracle Spatial
Francesco Sozzi fsozzi at INTERCAD.CH
Fri Mar 16 03:30:41 EDT 2007
No drawing of certain polygon rings stroed in Oracle SpatialAnother tip: what does it happen if you use "CIRCLE" instead of "POLYGON" in the layer definition in map file?...
Regards
Francesco
  ----- Original Message -----
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Sent: Thursday, March 15, 2007 1:54 PM
  Subject: [UMN_MAPSERVER-USERS] No drawing of certain polygon rings stroed in Oracle Spatial
  I have some troubles drawing of certain geometries, stored in Oracle Spatial 9i.
  In general, I'm able to say, that polygon rings are drawn without problems (Connected by line strings or compound line strings connected by circular arcs AND line strings). But there are some types, which are not drawn by mapserver. There is no warning or error reported by mapserver ! These certain geometries only are not present in the drawn png-file (or what ever). The geometries in the neighbourhood are drawn !
  My Environment
  - Oracle 9i with Spatial Option on a Windows 2003 Server
  - MapServer 4.8.4 (Mapserver 4.10.1 does the same !) on a SuSE SLES 9 compiled with an Oracle 10g - Client
  - MapServer used as WMS-Server
  In detail the geometry, whis is NOT drawn by mapserver
  Our application (Autodesk Topoase 3) is not storing a circle as a circle in Oracle Spatial. The circle is splitted into two arcs, connected to each other at the end-/start-points of the arcs. The drawn picture should be the picture of a circle.
  The stored geometry has the properties:
  GTYPE 2003 (= 2-dim POLYGON)
  In Detail:
  (2003; 82032; ; (1; 1003; 2; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ); (4505542,97176542; 5430753,10554764; 4505541,58808944; 5430750,58265205; 4505544,16794032; 5430749,30831663; 4505545,28931113; 5430751,74858283; 4505542,97176542; 5430753,10554764; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ))
  The geometry validates (SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT), the result is TRUE.
  The same geometry stored as LINE or CURVE IS drawn !!
  GTYPE 2002  (= 2-dim LINE or CURVE)
  (2002; 82032; ; (1; 2; 2; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ); (4505542,97176542; 5430753,10554764; 4505541,58808944; 5430750,58265206; 4505544,16794032; 5430749,30831663; 4505545,28931113; 5430751,74858283; 4505542,97176542; 5430753,10554764; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ))
  Note
  Changing the mapserver Layer TYPE from POLYGON to LINE (or vice versa) does not have any effect !!!
  In detail a "circle", which IS drawn by mapserver
  (2002; 82032; ; (1; 4; 1; 1; 2; 2; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ); (4506079,8746; 5430398,0938; 4506070,0144; 5430388,2336; 4506079,8746; 5430378,3734; 4506089,7348; 5430388,2336; 4506079,8746; 5430398,0938; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ))
  The geometry also validates (SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT), the result is TRUE.
  BUT:
  Please look at the first triplet of SDO_ELEM_INFO.
  Looking in Oracle Documentation, the combination of SDO_ETYPE=4 with a SDO_INTERPRETATION=1 is NOT allowed. SDO_INTERPRETATION MUST be bigger than 1.
  (Is there a bug in the doc ??????)
  My problem
  Creating new circles, the application stores them as GTYPE 2003, which is not drawn !
  Does anybody know, what's the matter?
  Is there anybody, who has some tipps for me ?
  With kind regards
  Schönhammer Herbert
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070316/9fa9da95/attachment.html
