fastcgi under Mapserver MS4W environment
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Mon Mar 19 13:11:12 EDT 2007
Comments inline:
John Mitchell wrote:
> Hi,
> I would like to use fastcgi for the MS4W environment, and I have
> explored the following link:
> http://mapserver.gis.umn.edu/docs/howto/fastcgi
> which says the following:
> <http://mapserver.gis.umn.edu/docs/howto/fastcgi/#table-of-contents>
> FastCGI on Win32
> MS4W Users
> MS4W (MapServer for Windows) <http://www.maptools.org/ms4w/> >= version
> 2.2.2 contains MapServer compiled with FastCGI support. However MS4W
> does not contain the required Apache module mod_fastcgi, because the
> module must be compiled to work with the Apache 2.2.x series (MS4W
> contains Apache 2.2.4). If you compile this please contribute it back to
> the MS4W mailing list
> <http://lists.maptools.org/mailman/listinfo/ms4w-users>.
That doc is uptodate and correct for this.
> It appears from above that I need module mod_fastcgi compiled. Has
> anyone done this?
No one has contributed this yet.
> Is fast-cgi running within mapserver when setup in the following way:
> MS4W setup with latest FWTools bin content copied into MS4W
> apache\cgi-bin. I run mapserv -v and it says fastcgi. Is their anything
> else that I have to do?
Using the latest MS4W out-of-the-box will also give you that mapserv -v
fastcgi message.
Also, are you aware that MS4W has it's own mailing list? (you even
included the link in your email)
jeff
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
