command line works, browser fails
János Gonzales
janos.gonzales at GMAIL.COM
Mon Mar 19 17:18:30 EDT 2007
Hello,
I am running mapserver on Windows/Apache with the binaries from
maptools.org. One of my layers is an ArcSDE layer. When I run
mapserver through the command line with QUERY_STRING , like so:
mapserv.exe QUERY_STRING="map=test.map&layer=sdelayer ..."
I get the output that would normally go into an html page. If I check
the output directory I see that the image created from the SDE layer
is there.
However, when accessing mapserver via a url with the same query
string, I get a "500 internal server error". Apache error log just
reports "Premature end of script headers" and the mapserver log
reports nothing.
My questions:
1. Does this have anything to do with setting permissions for the sde dlls?
2. Does anybody know how to see what errors are actually happening in
this case?
Thanks
