fastcgi under Mapserver MS4W environment
José Ramón López
joseramonlopez at GMAIL.COM
Tue Mar 20 03:47:27 EDT 2007
Hi people.
I have found this mod_fastcgi module compiled for windows in this site.
http://www.apachelounge.com/download/
I have configured apache to load this module, with directive "Loadmodule ...
" but i dont know what more thing i have to do to works fine.
Does anybody knows how to configure apache (ms4w) to works with mod_fastcgi?
Thxs.
2007/3/19, Jeff McKenna <jmckenna at dmsolutions.ca >:
> Comments inline:
> John Mitchell wrote:
> > Hi,
> > I would like to use fastcgi for the MS4W environment, and I have
> > explored the following link:
> > http://mapserver.gis.umn.edu/docs/howto/fastcgi
> > which says the following:
> > <http://mapserver.gis.umn.edu/docs/howto/fastcgi/#table-of-contents
> > FastCGI on Win32
> http://mapserver.gis.umn.edu/docs/howto/fastcgi/#table-of-contents >
> > MS4W Users
> http://mapserver.gis.umn.edu/docs/howto/fastcgi/#table-of-contents>
> > MS4W (MapServer for Windows) <http://www.maptools.org/ms4w/> >= version
> > 2.2.2 contains MapServer compiled with FastCGI support. However MS4W
> > does not contain the required Apache module mod_fastcgi, because the
> > module must be compiled to work with the Apache 2.2.x series (MS4W
> > contains Apache 2.2.4). If you compile this please contribute it back to
> > the MS4W mailing list
> > < http://lists.maptools.org/mailman/listinfo/ms4w-users>.
> That doc is uptodate and correct for this.
> > It appears from above that I need module mod_fastcgi compiled. Has
> > anyone done this?
> No one has contributed this yet.
> > Is fast-cgi running within mapserver when setup in the following way:
> > MS4W setup with latest FWTools bin content copied into MS4W
> > apache\cgi-bin. I run mapserv -v and it says fastcgi. Is their anything
> > else that I have to do?
> Using the latest MS4W out-of-the-box will also give you that mapserv -v
> fastcgi message.
> Also, are you aware that MS4W has it's own mailing list? (you even
> included the link in your email)
> jeff
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
José Ramón López
Tfno: 627 88 88 24
José Ramón López
Tfno: 627 88 88 24
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070320/0ad5b12b/attachment.html
