SLD ignoring fill-opacity
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Thu Mar 22 11:08:49 EDT 2007
Hi There,
  There was a thread explaining the status on the support of opacity at
feature level and sld :
http://www.nabble.com/mapserver-support-for-sld-opacity-fills-tf3439962.html
Later,
Pablo Rodríguez Madroño wrote:
> Good afternoon,
> I am using a very simple SLD document in a Java mapscript application under Windows, and it seems to ignore the fill-opacity and the width CSSParameters.
> This is my SLD document, which is correctly loaded:
> <?xml version="1.0" encoding="UTF-8"?>
> <StyledLayerDescriptor version="1.0.0"
> 	xmlns="http://www.opengis.net/sld"
> 	xmlns:gml="http://www.opengis.net/gml"
> 	xmlns:ogc="http://www.opengis.net/ogc"
> 	xmlns:xlink="http://www.w3.org/1999/xlink"
> 	xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> 	xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
> 	<NamedLayer>
> 		<Name>Demarcaciones</Name>
> 		<UserStyle>
> 			<Name>TRANSPARENT-POLYGON-GRAY</Name>
> 			<FeatureTypeStyle>
> 				<Rule>
> 					<PolygonSymbolizer>
> 						<Fill>
> 							<!--<CssParameter name="fill">#666666</CssParameter>-->
> 							<CssParameter name="fill-opacity">0.5</CssParameter>
> 						</Fill>
> 						<Stroke>
> 							<!--<CssParameter name="stroke">#726E65</CssParameter>-->
> 							<CssParameter name="width">1</CssParameter>
> 						</Stroke>
> 					</PolygonSymbolizer>
> 				</Rule>
> 			</FeatureTypeStyle>
> 		</UserStyle>
> 	</NamedLayer>
> </StyledLayerDescriptor>
> The document is parsed with default values (so it ignores fill-opacity and width). If the other two CssParameters are uncommented only them are taken into consideration.
> The Java code is very simple, so I am not attaching it (if you need it I can post it).
> Is there any solution which does not pass through a mapfile workaround?
> Thank you very much,
> División de Sistemas de Información
> ADASA Sistemas
> 93.264.06.02
> 600.92.65.10
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
