geotiff problem since update
William Reid
wer at CSTONE.NET
Sat Mar 24 00:48:06 EDT 2007
Frank.
You are a gentlemen and a scholar! Thank you so much for all you do!
-=Bill
Frank Warmerdam wrote:
> William Reid wrote:
>> The TAB file has this. (originates from EDX software for doing RF
>> predictions, so if I find the problem I would like to help clue them
>> in as well)
>> !table
>> !version 300
>> !charset WindowsLatin1
>> Definition Table
>> File "Carters2.tif"
>> Type "RASTER"
>> (-78.784164,38.19123) (0,0) Label "",
>> (-78.782352,37.789336) (0,1200) Label "",
>> (-78.117974,38.19123) (1600,0) Label "",
>> (-78.119787,37.789336) (1600,1200) Label ""
>> CoordSys Earth Projection 1, 104
>> Units "degree"
> William,
> Ah! That could explain it. The handling of TAB files for georeferencing
> of TIFFs has no doubt changed. At the point where gdalinfo reports the
> GCPs associated with your image, do the following to "warp to north up":
> gdalwarp your.tif your_simple.tif
> In fact your image is already *almost* north up so this shouldn't change
> it much, but it will turn it into a geotiff with simple "world file like"
> information. The output file should work fine with mapserver.
> Best regards,
