Mapserver And Oracle Client 10g Integration Problem
Joydip Shome
joydip at ETRANSINFO.COM
Sun Mar 25 06:20:39 EDT 2007
I am configuring Mapserver with Oracle Spatial 10g on RedHat 4 ES.
Though I have cleared all comilation error, but I do not get
"INPUT=ORACLESPATIAL" with "mapserv -v"
Please Help.
Joydip Shome
joydip at etransinfo.com
+919831077172
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for flex... flex
checking for yywrap in -lfl... yes
checking lex output file root... lex.yy
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for exp in -lm... yes
checking for __gxx_personality_v0 in -lstdc++... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
checking for strlcat... no
checking for vsnprintf... yes
MapServer Version from map.h: '4.10.1'
configure: checking where FreeType 2.x is installed...
checking for FT_Init_FreeType in -lfreetype... yes
using libfreetype -lfreetype from system libs.
configure: checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs (-DUSE_ZLIB).
configure: checking where PNG is installed...
checking for png_init_io in -lpng... yes
using libpng from system libs.
configure: checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
configure: checking where libXpm is installed...
checking for XpmFreeXpmImage in -lXpm... no
XPM (libXpm) library cannot be found, possibly needed for GD
configure: checking where libiconv is installed...
checking for iconv_open in -lc... yes
checking for libiconv_open in -liconv... no
using libiconv from system libs.
libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.16 or higher...
checking for gdFontCacheSetup in -lgd... yes
using libgd 2.0.16 (or higher) from system libs (-L/usr/lib -lgd
-ljpeg -lfreetype -lpng -lz ).
checking for gdImageCreate in -lgd... yes
checking for gdImageGif in -lgd... yes
checking for gdImagePng in -lgd... yes
checking for gdImageJpeg in -lgd... yes
checking for gdImageWBMP in -lgd... yes
checking for gdImageStringFT in -lgd... yes
checking for gdImageOpenPolygon in -lgd... no
checking for gdImageGifPtr in -lgd... yes
checking for gdFontGetTiny in -lgd... yes
using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS) from system libs.
configure: checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... no
libpdf not found... PDF support not included.
configure: checking whether we should include EPPL7 support...
including EPPL7 support.
configure: checking whether we should include PROJ.4 support...
checking for pj_init in -lproj... yes
checking for pj_transform in -lproj... yes
using PROJ.4 from system libs.
configure: checking whether we should include thread safe support...
thread safe support disabled.
configure: checking whether we should include ESRI SDE support...
ESRI SDE support not requested.
checking if GEOS support requested... no
configure: checking whether we should include OGR support...
checking for gdal-config... /usr/local/bin/gdal-config
OGR enabled (-DUSE_OGR).
checking if GDAL support requested... yes
checking checking ms JPEG output... no we, have GDAL available.
configure: checking whether we should include TIFF support...
disabled since gdal is in use
checking if PostGIS support requested... no
checking if MyGIS support requested... no
checking if OracleSpatial support requested... yes, set from ORACLE_HOME
environment variable
Oracle Spatial found in /oracle/u01/product/CLIENT/10.1.0.3.
checking if MING/Flash support requested... no
configure: checking whether we should include WMS Server support...
OGC WMS compatibility enabled (-DUSE_WMS_SVR).
configure: checking whether we should include WFS Server support...
OGC WFS Server support not requested.
configure: checking whether we should include WCS Server support...
OGC WCS Server support not requested.
configure: checking whether we should include WMS Client Connections support...
configure: checking whether we should include WFS Client Connections support...
configure: checking whether we should include OGC SOS Server support...
configure: checking for curl-config...
configure: checking for xml2-config...
configure: checking whether FastCGI support should be enabled...
FastCGI support not enabled.
configure: checking HTTPD server (Apache) version...
checking for httpd... /usr/sbin/httpd
/usr/sbin/httpd version is Apache/2.0.52 (2000052).
Compiling with fast MS_NINT
checking compiler warnings... basic
configure: checking whether we should enable debug features...
configure: checking for PHP/MapScript module options...
PHP/MapScript module not configured.
checking for g++ -shared ... yes
checking if --enable-runpath requested... no
checking if --with-java-include-os-name specified... no, autodetected linux
configure: creating ./config.status
config.status: creating Makefile
config.status: creating mapscript/java/Makefile
config.status: creating mapscript/csharp/Makefile
usage: more [-dflpcsu] [+linenum | +/pattern] name1 name2 ...
touch mapscriptvars
pwd > mapscriptvars
echo -DHAVE_VSNPRINTF -DNEED_STRLCAT -DUSE_EPPL -DUSE_PROJ
-DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
-DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_OGR -DUSE_GDAL
-DUSE_WMS_SVR >> mapscriptvars
echo -I. -I/usr/include -I/usr/local/include >> mapscriptvars
echo -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz -ljpeg
-lfreetype -lpng -lz -lproj -ljpeg -L/usr/local/lib -lgdal
-L/oracle/u01/product/DB/10.1.0.3/lib -lclntsh -lodbc -lodbcinst -lgif
-ljpeg -ltiff -lpng -lpq -L/usr/lib -lpq -lz -lm -lrt -ldl -L/usr/lib -lcurl
-L/usr/kerberos/lib -lssl -lcrypto -lgssapi_krb5 -lkrb5 -lcom_err -lk5crypto
-lresolv -ldl -lz -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lresolv
-L/usr/kerberos/lib -lidn -lssl -lcrypto -lssl -lcrypto -lgssapi_krb5 -lkrb5
-lcom_err -lk5crypto -lresolv -ldl -lz -lz
-L/oracle/u01/product/CLIENT/10.1.0.3/lib -lclntsh -lc -lz -lm -lstdc++
>> mapscriptvars
echo >> mapscriptvars
grep '#define MS_VERSION' map.h >> mapscriptvars
MapServer version 4.10.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
