layer filters issue
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Mon Mar 26 20:39:13 EDT 2007
using:
MapServer latest CVS
GDAL 1.4.0
Windows Server 2003
Using MS SQL Server
GDAL / OGR VRT driver
LAYER object:
LAYER
  NAME "water_data"
  STATUS ON
  CONNECTIONTYPE OGR
  DATA "water_data"
  TYPE POINT
  DEBUG ON
  FILTER "where Site_Number = 'NF02YC0001'" # this works, filter is passed
  #FILTER "Site_Number = 'NF02YC0001'" # no results
  DUMP TRUE
  #GROUP WaterMonitoring
  CONNECTION "<OGRVRTDataSource>
  <OGRVRTLayer name='water_data'>
  <SrcDataSource>ODBC:foo/bar at foodb</SrcDataSource>
  <SrcSQL>SELECT * FROM foodata</SrcSQL>
  <FID>VMVCode</FID>
  <GeometryType>wkbPoint</GeometryType>
  <LayerSRS>WGS84</LayerSRS>
  <GeometryField encoding='PointFromColumns' useSpatialSubquery='TRUE' x='X' y='Y'/>
  </OGRVRTLayer>
  </OGRVRTDataSource>"
  PROJECTION
    "init=epsg:4326"
  END
docs say (http://mapserver.gis.umn.edu/docs/reference/mapfile/layer#filter):
"FILTER [string]
    This parameter allows for data specific attribute filtering that is done at the same time spatial filtering is done, but before any CLASS expressions are evaluated. For OGR and shapefiles the string is simply a mapserver regular expression. For spatial databases the string is a SQL WHERE clause that is valid with respect to the underlying database.
    For example: FILTER "type='road' and size <2"
...so, according to the docs, this means that the FILTER statement above should be invalid, and I should NOT include a WHERE clause because this is an OGR type, NOT a spatial database.
Is this is a bug in the code, or should the docs be modified?
Thanks
..Tom
