MapServer performance
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Tue Mar 27 06:54:03 EDT 2007
Hi Antti,
which version of VMWare? 3 or 4?
We have a significant performance drop in Mapserver (about a factor 3)
running on VMWare 3. VMWare 4 is supposed to have better performance for
this type of application.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: antti siukola <siukola.antti at GMAIL.COM>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-USERS] MapServer performance
Datum: 27/03/07 08:52
> Hi!
> I finally got some specs for our server. We have an vmware Virtual
> infrastructure 3 with fysical hardware of Dell PE 6850 dual dual-core
> cpu with 12 GB of RAM. Hard drives are EMC CX3-20 SAN system. And the
> system allocates 1GB RAM for us.
> Antti S
> On 3/27/07, Romolo Manfredini <romoloman at hotmail.com> wrote:
> > From: "Rahkonen Jukka"
> > > My test system has 3 GHz prosessor and 1 GB of memory. I have
on an
> > external Firewire 400 unit worth 2 TB of imagery, consisting or
> > > individual 300 MB GeoTIFF images. Those are uncompressed and
with
> > overviews, but untiled. I have made layers out of those by creating
> > > tileindices. When I run test with Jmeter by sending simple,
unique WMS
> > request hitting 1-4 original GeoTIFF files the throughput is around
200
> > > requests per minute. The size of the output image is 500 by 500
pixels
> > and the requests are tuned to suit the original resolution.
> > You can try performing Jmeter test against a very simple php script
that
> > output a map, so you can understand the phpmapscript overhead.
> > I'm not in condition to perform such a test on my high-end server and
the
> > test server is really downsized so i would not take my results as
reliable,
> > sorry.
> > Romolo Manfredini
