Problem with zoomPoint()
Jan Ciriack
janc44 at GMX.DE
Tue Mar 27 17:15:17 EDT 2007
I am using the mapscript libraries that came with the current ms4w package.
Here is my problem:
When I use the zoomPoint method like this everything works fine:
public static void main(String[] args) {
mapObj map = new mapObj("global.map");
pointObj point = new pointObj(300, 150, 0, 0);
map.zoomPoint(
2,
point,
map.getWidth(),
map.getHeight(),
map.getExtent(),
null);
imageObj img = map.draw();
img.save("worldmap.gif", map);
But when put the call of zoomPoint in a separate method like this it zooms to a
different point than the one I specified.
zoomToPoint(map, point, 2);
public static void zoomToPoint(mapObj map, pointObj point, int mode) {
map.zoomPoint(mode, point, map.getHeight(), map.getWidth(),map.getExtent(), null);
It is quite weird, isn't it? The other zooming methods work okay.
Any help more than appreciated.
Cheers,
Jan
