Mapscript crashing Tomcat --> [Panic]
Rodrigo Del C. Andrade
rodrigo.andrade at DIGITRO.COM.BR
Wed Mar 28 14:18:06 EDT 2007
Greetings. dear list.
We are experiencing some troubling difficulties developing an
application with mapscript on a Java web based environment with tomcat.
Here is the deal: while using the app (not nearly done, but
functional enough at this stage) when one tries to zoom (in or out) or
pan the map more than a few times, Tomcat often will go down screaming
and the JVM just gives up on life.
I know this is probably not the right or best place to ask about it,
but it seems to be caused by the interaction of mapscript and the GD
library.
Here is the JVM output short version (long version is attached at
the bottom):
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xada54182, pid=7851, tid=2955426704
# Java VM: Java HotSpot(TM) Client VM (1.5.0_07-b03 mixed mode, sharing)
# Problematic frame:
# C [libgd.so.2+0x8182]
If it helps narrowing down the cause: we have had this problem with
every windows box running a binary distro of MS4W version 4.8 (if I am
not mistaken) so far. We had one linux box running RHES 4 and mapscript
4.10 beta3 without this problem, but that machine has then been
decommissioned and replaced with a Fedora 6 box, the mapserver 4.10.1
install presented the problem. I have then replaced 4.10.1 with the old
4.10 beta3 and recompiled, but the problem still occurs.
Compile options where:
./configure --prefix=$MAPSERVER_HOME
--without-pdf
--with-threads
--with-zlib=/home2/mapserver/zlib
--with-png=/home2/mapserver/libpng
--with-tiff=/home2/mapserver/libtiff
--with-jpeg=/home2/mapserver/libjpeg
--with-freetype=/home2/mapserver/freetype
--with-proj=/home2/mapserver/proj4
--with-geos=/home2/mapserver/geos/bin/geos-config
--with-gd=/home2/mapserver/gd
--with-ogr=/home2/mapserver/gdal/bin/gdal-config
--with-gdal=/home2/mapserver/gdal/bin/gdal-config
--with-curl-config=/home2/mapserver/libcurl/bin/curl-config
--with-wfs
--with-wcs
--with-wmsclient
--with-wfsclient
--with-php=/usr/local/include/phpcm
I know theres a hell lot of addons in there, but as far as I know
this shouldnt be a problem. Also, every one of these libraries where
cleanly compiled from source. Mapscript passes all the tests in "make
test" after compiled it creates a sane libmapscript.so and mapscript.jar.
Like I said, it all works fine for a while, but then it kills Tomcat
after some use.
Any ideas? Full JVM error log is at the bottom. I am ready to give
in more info if needed.
Thanks in advance;
Rodrigo
--------------- T H R E A D ---------------
Current thread (0x094619e8): JavaThread "http-8080-Processor25" daemon
[_thread_in_native, id=7913]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x61747cda
Registers:
EAX=0x61746f6e, EBX=0xada68618, ECX=0xffffff31, EDX=0x00000000
ESP=0xb0279ed4, EBP=0xb0279f0c, ESI=0x0000035b, EDI=0xffff47b9
EIP=0xada54182, CR2=0x61747cda, EFLAGS=0x00210246
Top of Stack: (sp=0xb0279ed4)
0xb0279ed4: 098ea978 0000035b 000001b8 000000cf
0xb0279ee4: 098ea0e0 61746f6e 000001b8 0000035b
0xb0279ef4: 098ea978 000000b9 00000075 ada68618
0xb0279f04: 01b70000 0000035b b0279ffc ada55a16
0xb0279f14: 00cfb975 000000ff 000001b7 00000000
0xb0279f24: b027a528 0013cc71 0000035b 00000000
0xb0279f34: 00000000 00000000 00000000 00000000
0xb0279f44: 00000000 00000000 00000000 00000000
Instructions: (pc=0xada54182)
0xada54172: 00 00 c1 f8 08 03 45 ec c1 e0 08 01 c2 8b 45 dc
0xada54182: 89 14 b0 8b 5d f4 8b 75 f8 8b 7d fc 89 ec 5d c3
Stack: [0xb0203000,0xb0284000), sp=0xb0279ed4, free space=475k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
C=native code)
C [libgd.so.2+0x9a16] gdImageLine+0x4a6
C [libmapscript.so+0xad355]
C [libmapscript.so+0xb310e] msDrawLineSymbolGD+0xe7e
C [libmapscript.so+0xa75fb] msDrawLineSymbol+0x8b
C [libmapscript.so+0xa9cb2] msDrawShape+0x17e2
C [libmapscript.so+0xaa6d8] msDrawVectorLayer+0x398
C [libmapscript.so+0xaa97a] msDrawLayer+0xaa
C [libmapscript.so+0xaba67] msDrawMap+0x6a7
C [libmapscript.so+0x552b5]
Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1draw+0x45
j edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw(J)J+0
j edu.umn.gis.mapscript.mapObj.draw()Ledu/umn/gis/mapscript/imageObj;+4
j
br.com.company.appgis.model.appGisMapFactory.drawMap(Ledu/umn/gis/mapscript/mapObj;Ljava/io/File;Ljava/io/File;)V+6
j
br.com.company.appgis.model.appGisMapFactory.createMapa(Ljava/util/Map;Ljava/util/List;)Lbr/com/company/appgis/model/vo/MapaVO;+208
j
br.com.company.appgis.model.appGisService.buildMapa(Ljava/util/Map;Ljava/util/List;)Lbr/com/company/appgis/model/vo/MapaVO;+2
j
br.com.company.app.gis.action.MapaAction.criaMapa(Ljavax/servlet/http/HttpServletRequest;)V+11
j
br.com.company.app.gis.action.MapaAction.dvimgmapa(Lorg/apache/struts/action/ActionMapping;Lorg/apache/struts/action/DynaActionForm;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Lorg/apache/struts/action/ActionMessages;)Lorg/apache/struts/action/ActionForward;+2
v ~StubRoutines::call_stub
V [libjvm.so+0x17900c]
V [libjvm.so+0x286278]
V [libjvm.so+0x178e3f]
V [libjvm.so+0x2affec]
V [libjvm.so+0x2b2cea]
V [libjvm.so+0x1ecd62]
C [libjava.so+0x13764]
Java_sun_reflect_NativeMethodAccessorImpl_invoke0+0x34
J
sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
J
sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
J
sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
J
java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
j
br.com.company.utilweb.action.AGISAction.execute(Lorg/apache/struts/action/ActionMapping;Lorg/apache/struts/action/ActionForm;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)Lorg/apache/struts/action/ActionForward;+81
j
org.apache.struts.action.RequestProcessor.processActionPerform(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Lorg/apache/struts/action/Action;Lorg/apache/struts/action/ActionForm;Lorg/apache/struts/action/ActionMapping;)Lorg/apache/struts/action/ActionForward;+7
j
org.apache.struts.action.RequestProcessor.process(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+219
j
org.apache.struts.action.ActionServlet.process(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+40
j
org.apache.struts.action.ActionServlet.doPost(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+3
j
javax.servlet.http.HttpServlet.service(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+139
j
javax.servlet.http.HttpServlet.service(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+30
j
sun.reflect.GeneratedMethodAccessor81.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+48
J
J
j org.apache.catalina.security.SecurityUtil$1.run()Ljava/lang/Object;+12
V [libjvm.so+0x1d64fd]
C [libjava.so+0x93bc]
Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedExceptionAction_2Ljava_security_AccessControlContext_2+0x3c
j
java.security.AccessController.doPrivileged(Ljava/security/PrivilegedExceptionAction;Ljava/security/AccessControlContext;)Ljava/lang/Object;+0
j
javax.security.auth.Subject.doAsPrivileged(Ljavax/security/auth/Subject;Ljava/security/PrivilegedExceptionAction;Ljava/security/AccessControlContext;)Ljava/lang/Object;+60
j
org.apache.catalina.security.SecurityUtil.execute(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;Ljava/security/Principal;)V+136
j
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Ljava/lang/String;Ljavax/servlet/Servlet;[Ljava/lang/Class;[Ljava/lang/Object;Ljava/security/Principal;)V+70
j
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+333
j
org.apache.catalina.core.ApplicationFilterChain.access$000(Lorg/apache/catalina/core/ApplicationFilterChain;Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+3
j
org.apache.catalina.core.ApplicationFilterChain$1.run()Ljava/lang/Object;+12
C [libjava.so+0x936d]
Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedExceptionAction_2+0x3d
j
java.security.AccessController.doPrivileged(Ljava/security/PrivilegedExceptionAction;)Ljava/lang/Object;+0
j
org.apache.catalina.core.ApplicationFilterChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+22
j
br.com.company.app.filter.AuthFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+276
J
J
J
J
v ~RuntimeStub::alignment_frame_return Runtime1 stub
j
j
j
j
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Ljava/lang/String;Ljavax/servlet/Filter;[Ljava/lang/Class;[Ljava/lang/Object;)V+69
j
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+103
j
j
j
j
j
org.apache.catalina.core.StandardWrapperValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+670
j
org.apache.catalina.core.StandardContextValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+285
j
org.apache.catalina.authenticator.AuthenticatorBase.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+675
...<more frames>...
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j
j
j
j
j
J
J
J
J
j
j
j
j
j
j
j
j
J
J
j
j
j
j
j
j
j
j
j
j
J
J
J
J
j
j
j
j
j
j
j
j
j
j
j
j
j
org.apache.catalina.core.StandardHostValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+64
j
org.apache.catalina.valves.ErrorReportValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+6
j
org.apache.catalina.authenticator.SingleSignOn.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+451
j
org.apache.catalina.core.StandardEngineValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V+42
j
org.apache.catalina.connector.CoyoteAdapter.service(Lorg/apache/coyote/Request;Lorg/apache/coyote/Response;)V+141
j
org.apache.coyote.http11.Http11Processor.process(Ljava/io/InputStream;Ljava/io/OutputStream;)V+566
j
org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Lorg/apache/tomcat/util/net/TcpConnection;[Ljava/lang/Object;)V+113
j
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Ljava/net/Socket;Lorg/apache/tomcat/util/net/TcpConnection;[Ljava/lang/Object;)V+45
j
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt([Ljava/lang/Object;)V+102
j org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run()V+167
j java.lang.Thread.run()V+11
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x09923858 JavaThread "Prototyper" daemon [_thread_blocked, id=7930]
0x09924e38 JavaThread "HouseKeeper" daemon [_thread_blocked, id=7929]
0x098b9f40 JavaThread "Thread-40" daemon [_thread_blocked, id=7928]
0x098b91c8 JavaThread "Thread-39" daemon [_thread_blocked, id=7927]
0x098b8cf0 JavaThread "Thread-38" daemon [_thread_blocked, id=7926]
0x094d9770 JavaThread "TP-Monitor" daemon [_thread_blocked, id=7919]
0x09857630 JavaThread "TP-Processor4" daemon [_thread_in_native, id=7918]
0x098568b8 JavaThread "TP-Processor3" daemon [_thread_blocked, id=7917]
0x0981eb48 JavaThread "TP-Processor2" daemon [_thread_blocked, id=7916]
0x0981e720 JavaThread "TP-Processor1" daemon [_thread_blocked, id=7915]
0x094628e8 JavaThread "http-8080-Monitor" [_thread_blocked, id=7914]
=>0x094619e8 JavaThread "http-8080-Processor25" daemon
0x09460ae8 JavaThread "http-8080-Processor24" daemon
[_thread_in_native, id=7912]
0x09790bb0 JavaThread "http-8080-Processor23" daemon
[_thread_in_native, id=7911]
0x0978fcb0 JavaThread "http-8080-Processor22" daemon [_thread_blocked,
id=7910]
0x0978edb0 JavaThread "http-8080-Processor21" daemon [_thread_blocked,
id=7909]
0x09327cf8 JavaThread "http-8080-Processor20" daemon [_thread_blocked,
id=7908]
0x09326df8 JavaThread "http-8080-Processor19" daemon [_thread_blocked,
id=7907]
0x09325d80 JavaThread "http-8080-Processor18" daemon [_thread_blocked,
id=7906]
0x0938f2b0 JavaThread "http-8080-Processor17" daemon [_thread_blocked,
id=7905]
0x0938e3b0 JavaThread "http-8080-Processor16" daemon [_thread_blocked,
id=7904]
0x0938d500 JavaThread "http-8080-Processor15" daemon [_thread_blocked,
id=7903]
0x09471b00 JavaThread "http-8080-Processor14" daemon [_thread_blocked,
id=7902]
0x09470c88 JavaThread "http-8080-Processor13" daemon [_thread_blocked,
id=7901]
0x09283a18 JavaThread "http-8080-Processor12" daemon [_thread_blocked,
id=7900]
0x09282b18 JavaThread "http-8080-Processor11" daemon [_thread_blocked,
id=7899]
0x09281c18 JavaThread "http-8080-Processor10" daemon [_thread_blocked,
id=7898]
0x092f2a78 JavaThread "http-8080-Processor9" daemon [_thread_blocked,
id=7897]
0x092e49d0 JavaThread "http-8080-Processor8" daemon [_thread_blocked,
id=7896]
0x093437d0 JavaThread "http-8080-Processor7" daemon [_thread_blocked,
id=7895]
0x0978bc10 JavaThread "http-8080-Processor6" daemon [_thread_blocked,
id=7894]
0x092580d8 JavaThread "http-8080-Processor5" daemon [_thread_blocked,
id=7893]
0x092382b0 JavaThread "http-8080-Processor4" daemon [_thread_blocked,
id=7892]
0x09238128 JavaThread "http-8080-Processor3" daemon [_thread_blocked,
id=7891]
0x09485198 JavaThread "http-8080-Processor2" daemon [_thread_blocked,
id=7890]
0x094fe210 JavaThread "http-8080-Processor1" daemon [_thread_blocked,
id=7889]
0x092e53a8 JavaThread
"ContainerBackgroundProcessor[StandardEngine[Catalina]]" daemon
[_thread_blocked, id=7888]
0x09324c10 JavaThread "Prototyper" daemon [_thread_blocked, id=7868]
0x09325028 JavaThread "HouseKeeper" daemon [_thread_blocked, id=7867]
0x0937a190 JavaThread "Thread-3" daemon [_thread_blocked, id=7866]
0x093ad958 JavaThread "Thread-2" daemon [_thread_blocked, id=7865]
0x0937b4b0 JavaThread "Thread-1" daemon [_thread_blocked, id=7864]
0x0924c618 JavaThread "Low Memory Detector" daemon [_thread_blocked,
id=7862]
0x0924b070 JavaThread "CompilerThread0" daemon [_thread_blocked, id=7861]
0x0924a0c8 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
id=7860]
0x09243300 JavaThread "Finalizer" daemon [_thread_blocked, id=7859]
0x092425a8 JavaThread "Reference Handler" daemon [_thread_blocked,
id=7858]
0x092057a0 JavaThread "main" [_thread_in_native, id=7851]
Other Threads:
0x0923fa10 VMThread [id=7857]
0x0924db00 WatcherThread [id=7863]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 1344K, used 541K [0x88b70000, 0x88ce0000,
0x89050000)
eden space 1216K, 39% used [0x88b70000, 0x88be8a90, 0x88ca0000)
from space 128K, 46% used [0x88cc0000, 0x88ccebf0, 0x88ce0000)
to space 128K, 0% used [0x88ca0000, 0x88ca0000, 0x88cc0000)
tenured generation total 17356K, used 13779K [0x89050000, 0x8a143000,
0x8cb70000)
the space 17356K, 79% used [0x89050000, 0x89dc4f80, 0x89dc5000,
0x8a143000)
compacting perm gen total 23296K, used 23043K [0x8cb70000, 0x8e230000,
0x90b70000)
the space 23296K, 98% used [0x8cb70000, 0x8e1f0e98, 0x8e1f1000,
0x8e230000)
ro space 8192K, 68% used [0x90b70000, 0x910ee070, 0x910ee200,
0x91370000)
rw space 12288K, 48% used [0x91370000, 0x91935130, 0x91935200,
0x91f70000)
Dynamic libraries:
00101000-00238000 r-xp 00000000 03:03 963025 /lib/libc-2.5.so
00238000-0023a000 r-xp 00137000 03:03 963025 /lib/libc-2.5.so
0023a000-0023b000 rwxp 00139000 03:03 963025 /lib/libc-2.5.so
0023b000-0023e000 rwxp 0023b000 00:00 0
00240000-0033e000 r-xp 00000000 03:03 254862 /usr/lib/libX11.so.6.2.0
0033e000-00342000 rwxp 000fe000 03:03 254862 /usr/lib/libX11.so.6.2.0
00344000-0034b000 r-xp 00000000 03:03 1035444 /lib/librt-2.5.so
0034b000-0034c000 r-xp 00006000 03:03 1035444 /lib/librt-2.5.so
0034c000-0034d000 rwxp 00007000 03:03 1035444 /lib/librt-2.5.so
0034f000-0035a000 r-xp 00000000 03:03 1035450
/lib/libgcc_s-4.1.1-20061011.so.1
0035a000-0035b000 rwxp 0000a000 03:03 1035450
00362000-0037b000 r-xp 00000000 03:03 963015 /lib/ld-2.5.so
0037b000-0037c000 r-xp 00018000 03:03 963015 /lib/ld-2.5.so
0037c000-0037d000 rwxp 00019000 03:03 963015 /lib/ld-2.5.so
003ad000-003bd000 r-xp 00000000 03:03 232848 /usr/lib/libXpm.so.4.11.0
003bd000-003be000 rwxp 00010000 03:03 232848 /usr/lib/libXpm.so.4.11.0
0040e000-00410000 r-xp 00000000 03:03 1035459 /lib/libcom_err.so.2.1
00410000-00411000 rwxp 00001000 03:03 1035459 /lib/libcom_err.so.2.1
00413000-00498000 r-xp 00000000 03:03 254912 /usr/lib/libkrb5.so.3.2
00498000-0049a000 rwxp 00084000 03:03 254912 /usr/lib/libkrb5.so.3.2
0049c000-004c1000 r-xp 00000000 03:03 254911 /usr/lib/libk5crypto.so.3.0
004c1000-004c2000 rwxp 00025000 03:03 254911 /usr/lib/libk5crypto.so.3.0
004c4000-004cb000 r-xp 00000000 03:03 233178
/usr/lib/libkrb5support.so.0.1
004cb000-004cc000 rwxp 00006000 03:03 233178
00649000-00673000 r-xp 00000000 03:03 254913
/usr/lib/libgssapi_krb5.so.2.2
00673000-00674000 rwxp 00029000 03:03 254913
00cf3000-00d23000 r-xp 00000000 03:03 254886 /usr/lib/libidn.so.11.5.19
00d23000-00d24000 rwxp 0002f000 03:03 254886 /usr/lib/libidn.so.11.5.19
00d31000-00d56000 r-xp 00000000 03:03 1035448 /lib/libm-2.5.so
00d56000-00d57000 r-xp 00024000 03:03 1035448 /lib/libm-2.5.so
00d57000-00d58000 rwxp 00025000 03:03 1035448 /lib/libm-2.5.so
00d5a000-00d5c000 r-xp 00000000 03:03 1035442 /lib/libdl-2.5.so
00d5c000-00d5d000 r-xp 00001000 03:03 1035442 /lib/libdl-2.5.so
00d5d000-00d5e000 rwxp 00002000 03:03 1035442 /lib/libdl-2.5.so
00d60000-00d73000 r-xp 00000000 03:03 1035443 /lib/libpthread-2.5.so
00d73000-00d74000 r-xp 00012000 03:03 1035443 /lib/libpthread-2.5.so
00d74000-00d75000 rwxp 00013000 03:03 1035443 /lib/libpthread-2.5.so
00d75000-00d77000 rwxp 00d75000 00:00 0
00d79000-00d8b000 r-xp 00000000 03:03 254856 /usr/lib/libz.so.1.2.3
00d8b000-00d8c000 rwxp 00011000 03:03 254856 /usr/lib/libz.so.1.2.3
00d8e000-00d93000 r-xp 00000000 03:03 254861 /usr/lib/libXdmcp.so.6.0.0
00d93000-00d94000 rwxp 00004000 03:03 254861 /usr/lib/libXdmcp.so.6.0.0
00d96000-00d98000 r-xp 00000000 03:03 254860 /usr/lib/libXau.so.6.0.0
00d98000-00d99000 rwxp 00001000 03:03 254860 /usr/lib/libXau.so.6.0.0
00d9b000-00dba000 r-xp 00000000 03:03 1035449 /lib/libexpat.so.0.5.0
00dba000-00dbc000 rwxp 0001e000 03:03 1035449 /lib/libexpat.so.0.5.0
05378000-0539f000 r-xp 00000000 03:03 254858
/usr/lib/libfontconfig.so.1.1.0
0539f000-053a7000 rwxp 00027000 03:03 254858
053d1000-054b2000 r-xp 00000000 03:03 254883 /usr/lib/libstdc++.so.6.0.8
054b2000-054b6000 r-xp 000e0000 03:03 254883 /usr/lib/libstdc++.so.6.0.8
054b6000-054b7000 rwxp 000e4000 03:03 254883 /usr/lib/libstdc++.so.6.0.8
054b7000-054bd000 rwxp 054b7000 00:00 0
054e6000-05507000 r-xp 00000000 03:03 242303 /usr/lib/libjpeg.so.62.0.0
05507000-05508000 rwxp 00020000 03:03 242303 /usr/lib/libjpeg.so.62.0.0
05b41000-05b50000 r-xp 00000000 03:03 1035458 /lib/libresolv-2.5.so
05b50000-05b51000 r-xp 0000e000 03:03 1035458 /lib/libresolv-2.5.so
05b51000-05b52000 rwxp 0000f000 03:03 1035458 /lib/libresolv-2.5.so
05b52000-05b54000 rwxp 05b52000 00:00 0
05b56000-05b68000 r-xp 00000000 03:03 1035457 /lib/libnsl-2.5.so
05b68000-05b69000 r-xp 00012000 03:03 1035457 /lib/libnsl-2.5.so
05b69000-05b6a000 rwxp 00013000 03:03 1035457 /lib/libnsl-2.5.so
05b6a000-05b6c000 rwxp 05b6a000 00:00 0
08048000-08057000 r-xp 00000000 03:05 671332
/home2/java/jdk1.5.0_07/jre/bin/java
08057000-08059000 rwxp 0000e000 03:05 671332
09201000-0a87c000 rwxp 09201000 00:00 0
88b70000-88ce0000 rwxp 88b70000 00:00 0
88ce0000-89050000 rwxp 88ce0000 00:00 0
89050000-8a143000 rwxp 89050000 00:00 0
8a143000-8cb70000 rwxp 8a143000 00:00 0
8cb70000-8e230000 rwxp 8cb70000 00:00 0
8e230000-90b70000 rwxp 8e230000 00:00 0
90b70000-910ef000 r-xs 00001000 03:05 671961
/home2/java/jdk1.5.0_07/jre/lib/i386/client/classes.jsa
910ef000-91370000 rwxp 910ef000 00:00 0
91370000-91936000 rwxp 00580000 03:05 671961
91936000-91f70000 rwxp 91936000 00:00 0
91f70000-9203f000 rwxp 00b46000 03:05 671961
9203f000-92370000 rwxp 9203f000 00:00 0
92370000-92374000 r-xs 00c15000 03:05 671961
92374000-92770000 rwxp 92374000 00:00 0
ad295000-ad29d000 r-xp 00000000 03:03 232920 /usr/lib/libgif.so.4.1.3
ad29d000-ad29e000 rwxp 00007000 03:03 232920 /usr/lib/libgif.so.4.1.3
ad29e000-ad393000 r-xp 00000000 03:05 32522
/home2/mapserver/geos/lib/libgeos.so.2.2.3
ad393000-ad398000 rwxp 000f5000 03:05 32522
ad398000-ad3a4000 r-xp 00000000 03:05 32526
/home2/mapserver/geos/lib/libgeos_c.so.1.1.1
ad3a4000-ad3a5000 rwxp 0000c000 03:05 32526
ad3a5000-ad4c1000 r-xp 00000000 03:03 960018 /lib/libcrypto.so.0.9.8b
ad4c1000-ad4d3000 rwxp 0011c000 03:03 960018 /lib/libcrypto.so.0.9.8b
ad4d3000-ad4d7000 rwxp ad4d3000 00:00 0
ad4d7000-ad518000 r-xp 00000000 03:03 960029 /lib/libssl.so.0.9.8b
ad518000-ad51c000 rwxp 00040000 03:03 960029 /lib/libssl.so.0.9.8b
ad51c000-ad55f000 r-xp 00000000 03:05 32446
/home2/mapserver/libcurl/lib/libcurl.so.3.0.0
ad55f000-ad560000 rwxp 00043000 03:05 32446
ad560000-ad89c000 r-xp 00000000 03:05 64015
/home2/mapserver/gdal/lib/libgdal.so.1.10.0
ad89c000-ad8e9000 rwxp 0033b000 03:05 64015
ad8e9000-ad8ff000 rwxp ad8e9000 00:00 0
ad8ff000-ad93f000 r-xp 00000000 03:05 63977
/home2/mapserver/proj4/lib/libproj.so.0.5.0
ad93f000-ad941000 rwxp 0003f000 03:05 63977
ad941000-ad9ad000 r-xp 00000000 03:05 32127
/home2/mapserver/libtiff/lib/libtiff.so.3.8.2
ad9ad000-ad9af000 rwxp 0006c000 03:05 32127
ad9b9000-ad9c7000 r-xp 00000000 03:05 322918
/home2/mapserver/fonts/lsansd.ttf
ad9c7000-ad9e8000 r-xp 00000000 03:05 31974
/home2/mapserver/libpng/lib/libpng12.so.0.12.0
ad9e8000-ad9e9000 rwxp 00020000 03:05 31974
ad9e9000-ada49000 r-xp 00000000 03:05 32011
/home2/mapserver/freetype/lib/libfreetype.so.6.3.10
ada49000-ada4c000 rwxp 00060000 03:05 32011
ada4c000-ada68000 r-xp 00000000 03:05 32096
/home2/mapserver/gd/lib/libgd.so.2.0.0
ada68000-ada88000 rwxp 0001b000 03:05 32096
ada88000-ada9c000 rwxp ada88000 00:00 0
ada9c000-adbef000 r-xp 00000000 03:05 386273
/home2/install/mapserver/mapscript/java/libmapscript.so
adbef000-adbf3000 rwxp 00153000 03:05 386273
adbf3000-adbf4000 rwxp adbf3000 00:00 0
adbf4000-adbf7000 --xp adbf4000 00:00 0
adbf7000-adc75000 rwxp adbf7000 00:00 0
adc75000-adc78000 --xp adc75000 00:00 0
adc78000-adcf6000 rwxp adc78000 00:00 0
adcf6000-adcf9000 --xp adcf6000 00:00 0
adcf9000-add77000 rwxp adcf9000 00:00 0
add77000-add7a000 --xp add77000 00:00 0
add7a000-addf8000 rwxp add7a000 00:00 0
addf8000-addfb000 --xp addf8000 00:00 0
addfb000-ade79000 rwxp addfb000 00:00 0
ade79000-ade97000 r-xs 00000000 03:07 1057549
/company/workspaces/app/GISappWEB/WEB-INF/lib/xpp3-1.1.3_8.jar
ade97000-adeb3000 r-xs 00000000 03:07 1057535
/company/workspaces/app/GISappWEB/WEB-INF/lib/xmlrpc.jar
adeb3000-adeb4000 r-xs 00000000 03:07 1057531
/company/workspaces/app/GISappWEB/WEB-INF/lib/toggletag.jar
adeb4000-adf39000 r-xs 00000000 03:07 1057544
/company/workspaces/app/GISappWEB/WEB-INF/lib/struts.jar
adf39000-adf3c000 r-xs 00000000 03:07 1057499
/company/workspaces/app/GISappWEB/WEB-INF/lib/struts-legacy.jar
adf3c000-adfa2000 r-xs 00000000 03:07 1057541
/company/workspaces/app/GISappWEB/WEB-INF/lib/standard.jar
adfa2000-ae01c000 r-xs 00000000 03:07 1057474
/company/workspaces/app/GISappWEB/WEB-INF/lib/proxool.jar
ae01c000-ae0f5000 r-xs 00000000 03:07 1057486
/company/workspaces/app/GISappWEB/WEB-INF/lib/prefuse.jar
ae0f5000-ae194000 r-xs 00000000 03:07 1057562
/company/workspaces/app/GISappWEB/WEB-INF/lib/poi-scratchpad-3.0-alpha1-20050704.jar
ae194000-ae266000 r-xs 00000000 03:07 1057553
/company/workspaces/app/GISappWEB/WEB-INF/lib/poi-3.0-alpha1-20050704.jar
ae266000-ae38f000 r-xs 00000000 03:07 1057910
/company/workspaces/app/GISappWEB/WEB-INF/lib/oracle.jar
ae38f000-ae507000 r-xs 00000000 03:07 1057540
/company/workspaces/app/GISappWEB/WEB-INF/lib/ojdbc14.jar
ae507000-ae52b000 r-xs 00000000 03:07 1057563
/company/workspaces/app/GISappWEB/WEB-INF/lib/mapscript.jar
ae52b000-ae580000 r-xs 00000000 03:07 1057548
/company/workspaces/app/GISappWEB/WEB-INF/lib/mail.jar
ae580000-ae5d0000 r-xs 00000000 03:07 1057530
/company/workspaces/app/GISappWEB/WEB-INF/lib/lucene-1.4.3.jar
ae5d0000-ae62a000 r-xs 00000000 03:07 1057488
/company/workspaces/app/GISappWEB/WEB-INF/lib/looks-2.0.1.jar
ae62a000-ae682000 r-xs 00000000 03:07 1057561
/company/workspaces/app/GISappWEB/WEB-INF/lib/log4j-1.2.13.jar
ae682000-ae6ec000 r-xs 00000000 03:07 1057558
/company/workspaces/app/GISappWEB/WEB-INF/lib/jxl.jar
ae6ec000-ae70a000 r-xs 00000000 03:07 1057555
/company/workspaces/app/GISappWEB/WEB-INF/lib/junit-3.8.1.jar
ae70a000-ae70d000 r-xs 00000000 03:07 1057532
/company/workspaces/app/GISappWEB/WEB-INF/lib/jta.jar
ae70d000-ae713000 r-xs 00000000 03:07 1057533
/company/workspaces/app/GISappWEB/WEB-INF/lib/jstl.jar
ae713000-ae71d000 r-xs 00000000 03:07 1057559
/company/workspaces/app/GISappWEB/WEB-INF/lib/json-1.0.0.jar
ae71d000-ae73c000 r-xs 00000000 03:07 1057477
/company/workspaces/app/GISappWEB/WEB-INF/lib/jcalendar-1.3.2.jar
ae73c000-ae8b0000 r-xs 00000000 03:07 1057543
/company/workspaces/app/GISappWEB/WEB-INF/lib/jasperreports-1.2.7.jar
ae8b0000-ae8c0000 r-xs 00000000 03:07 1057484
/company/workspaces/app/GISappWEB/WEB-INF/lib/jakarta-oro.jar
ae8c0000-ae8ce000 r-xs 00000000 03:07 1057293
/company/workspaces/app/GISappWEB/WEB-INF/lib/app-util-1.0.0.jar
ae8ce000-ae8dc000 r-xs 00000000 03:07 1057328
/company/workspaces/app/GISappWEB/WEB-INF/lib/app-pojo-1.0.0.jar
ae8dc000-ae8de000 r-xs 00000000 03:07 1057417
/company/workspaces/app/GISappWEB/WEB-INF/lib/app-pessoas-1.0.0.jar
ae8de000-ae8e1000 r-xs 00000000 03:07 1057389
/company/workspaces/app/GISappWEB/WEB-INF/lib/app-gis-1.0.0.jar
ae8e1000-ae8e7000 r-xs 00000000 03:07 1057373
/company/workspaces/app/GISappWEB/WEB-INF/lib/app-dao-1.0.0.jar
ae8e7000-aeafb000 r-xs 00000000 03:07 1057506
/company/workspaces/app/GISappWEB/WEB-INF/lib/hibernate3.jar
aeafb000-aeb54000 r-xs 00000000 03:07 1057536
/company/workspaces/app/GISappWEB/WEB-INF/lib/hibernate-annotations.jar
aeb54000-aeb57000 r-xs 00000000 03:07 1057339
/company/workspaces/app/GISappWEB/WEB-INF/lib/generic-dao-1.0.1.jar
aeb57000-aeb58000 r-xs 00000000 03:07 1057554
/company/workspaces/app/GISappWEB/WEB-INF/lib/fileupload-ext.jar
aeb58000-aeb65000 r-xs 00000000 03:07 1057482
/company/workspaces/app/GISappWEB/WEB-INF/lib/ejb3-persistence.jar
aeb65000-aeb71000 r-xs 00000000 03:07 1057480
/company/workspaces/app/GISappWEB/WEB-INF/lib/ehcache-1.1.jar
aeb71000-aeb9e000 r-xs 00000000 03:07 1057492
/company/workspaces/app/GISappWEB/WEB-INF/lib/dwr.jar
aeb9e000-aebeb000 r-xs 00000000 03:07 1057478
/company/workspaces/app/GISappWEB/WEB-INF/lib/dom4j-1.6.1.jar
aebeb000-aebf3000 r-xs 00000000 03:07 1057537
/company/workspaces/app/GISappWEB/WEB-INF/lib/company-util-0.4.0.jar
aebf3000-aebfb000 r-xs 00000000 03:07 1057483
/company/workspaces/app/GISappWEB/WEB-INF/lib/company-license.jar
aebfb000-aebfe000 r-xs 00000000 03:07 1057505
/company/workspaces/app/GISappWEB/WEB-INF/lib/company-license-0.1.9.jar
aebfe000-aec07000 r-xs 00000000 03:07 1057327
/company/workspaces/app/GISappWEB/WEB-INF/lib/GIS-utilweb-1.0.0.jar
aec07000-aec24000 r-xs 00000000 03:07 1057209
/company/workspaces/app/GISappWEB/WEB-INF/lib/GIS-util-1.0.0.jar
aec24000-aec32000 r-xs 00000000 03:07 1057547
/company/workspaces/app/GISappWEB/WEB-INF/lib/daisy-util-1.4.1.jar
aec32000-aec47000 r-xs 00000000 03:07 1057476
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-validator.jar
aec47000-aec76000 r-xs 00000000 03:07 1057479
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-net.jar
aec76000-aec80000 r-xs 00000000 03:07 1057545
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-logging-1.0.4.jar
aec80000-aecac000 r-xs 00000000 03:07 1057551
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-lang.jar
aecac000-aecc1000 r-xs 00000000 03:07 1057560
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-io-1.3.jar
aecc1000-aed05000 r-xs 00000000 03:07 1057556
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-httpclient-3.0-rc2.jar
aed05000-aed0b000 r-xs 00000000 03:07 1057489
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-fileupload.jar
aed0b000-aed13000 r-xs 00000000 03:07 1057557
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-fileupload-1.1.jar
aed13000-aed2f000 r-xs 00000000 03:07 1057490
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-digester.jar
aed2f000-aedbf000 r-xs 00000000 03:07 1057487
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-collections.jar
aedbf000-aedde000 r-xs 00000000 03:07 1057485
/company/workspaces/app/GISappWEB/WEB-INF/lib/commons-beanutils.jar
aedde000-aee23000 r-xs 00000000 03:07 1057542
/company/workspaces/app/GISappWEB/WEB-INF/lib/cglib-2.1.3.jar
aee23000-aee40000 r-xs 00000000 03:07 1057546
/company/workspaces/app/GISappWEB/WEB-INF/lib/cewolf.jar
aee40000-aee47000 r-xs 00000000 03:07 1057539
/company/workspaces/app/GISappWEB/WEB-INF/lib/asm.jar
aee47000-aee4c000 r-xs 00000000 03:07 1057475
/company/workspaces/app/GISappWEB/WEB-INF/lib/asm-attrs.jar
aee4c000-aeeb9000 r-xs 00000000 03:07 1057534
/company/workspaces/app/GISappWEB/WEB-INF/lib/antlr-2.7.6rc1.jar
aeeb9000-aef23000 r-xs 00000000 03:07 1057491
/company/workspaces/app/GISappWEB/WEB-INF/lib/antlr-2.7.5H3.jar
aef23000-aef25000 r-xs 00000000 03:07 1057405
/company/workspaces/app/GISappWEB/WEB-INF/lib/analise-grafica-1.0.0.jar
aef25000-aef47000 r-xs 00000000 03:07 1057550
/company/workspaces/app/GISappWEB/WEB-INF/lib/Tidy.jar
aef47000-af26d000 r-xs 00000000 03:07 1057552
/company/workspaces/app/GISappWEB/WEB-INF/lib/PDFBox-0.7.2-log4j.jar
af26d000-af288000 r-xs 00000000 03:07 992141
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/xmlrpc-1.2-b1.jar
af288000-af2f4000 r-xs 00000000 03:07 992140
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/proxool-0.9.0RC2.jar
af2f4000-af323000 r-xs 00000000 03:07 992139
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/pg73jdbc3.jar
af323000-af442000 r-xs 00000000 03:07 993362
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/ojdbc14.jar
af442000-af499000 r-xs 00000000 03:07 992138
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/log4j-1.2.9.jar
af499000-af49c000 r-xs 00000000 03:07 992137
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/jta.jar
af49c000-af49e000 r-xs 00000000 03:07 992136
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/jdbc2_0-stdext.jar
af49e000-af6b7000 r-xs 00000000 03:07 992135
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/hibernate3.jar
af6b7000-af6ba000 r-xs 00000000 03:07 992133
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/fonetiza.jar
af6ba000-af707000 r-xs 00000000 03:07 992132
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/dom4j-1.6.jar
af707000-af70f000 r-xs 00000000 03:07 992131
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/company-util-0.3.1.jar
af70f000-af712000 r-xs 00000000 03:07 992130
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/company-seguranca.jar
af712000-af719000 r-xs 00000000 03:07 992129
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/company-license-0.3.2.jar
af719000-af723000 r-xs 00000000 03:07 992128
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/commons-logging-1.0.4.jar
af723000-af74d000 r-xs 00000000 03:07 992127
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/commons-lang-2.0.jar
af74d000-af778000 r-xs 00000000 03:07 992126
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/commons-collections-2.1.1.jar
af778000-af795000 r-xs 00000000 03:07 992125
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/commons-beanutils-1.6.1.jar
af795000-af7da000 r-xs 00000000 03:07 992124
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/cglib-2.1.jar
af7da000-af800000 r-xs 00000000 03:07 992123
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/cadpessoas.jar
af800000-af86d000 r-xs 00000000 03:07 992119
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/antlr-2.7.6.jar
af86d000-af889000 r-xs 00000000 03:07 993279
/company/workspaces/app/GISappInterface/WEB-INF/lib/xmlrpc.jar
af889000-af8a4000 r-xs 00000000 03:07 993278
/company/workspaces/app/GISappInterface/WEB-INF/lib/xmlrpc-1.2-b1.jar
af8a4000-af8a7000 r-xs 00000000 03:07 993275
/company/workspaces/app/GISappInterface/WEB-INF/lib/struts-legacy.jar
af8a7000-af90d000 r-xs 00000000 03:07 993272
/company/workspaces/app/GISappInterface/WEB-INF/lib/standard.jar
af90d000-af987000 r-xs 00000000 03:07 993268
/company/workspaces/app/GISappInterface/WEB-INF/lib/proxool.jar
af987000-af9fc000 r-xs 00000000 03:07 993267
/company/workspaces/app/GISappInterface/WEB-INF/lib/proxool-0.8.3.jar
af9fc000-afa20000 r-xs 00000000 03:07 993266
/company/workspaces/app/GISappInterface/WEB-INF/lib/mapscript.jar
afa20000-afa7b000 r-xs 00000000 03:07 993265
/company/workspaces/app/GISappInterface/WEB-INF/lib/log4j.jar
afa7b000-afa7e000 r-xs 00000000 03:07 993264
/company/workspaces/app/GISappInterface/WEB-INF/lib/jta.jar
afa7e000-afa84000 r-xs 00000000 03:07 993263
/company/workspaces/app/GISappInterface/WEB-INF/lib/jstl.jar
afa84000-afa94000 r-xs 00000000 03:07 993262
/company/workspaces/app/GISappInterface/WEB-INF/lib/jakarta-oro.jar
afa94000-afaa2000 r-xs 00000000 03:07 992496
/company/workspaces/app/GISappInterface/WEB-INF/lib/app-pojo-1.0.0.jar
afaa2000-afac4000 r-xs 00000000 03:07 993261
/company/workspaces/app/GISappInterface/WEB-INF/lib/guardiaoWebPojo.jar
afac4000-afaf1000 r-xs 00000000 03:07 993260
/company/workspaces/app/GISappInterface/WEB-INF/lib/dwr.jar
afaf1000-afb68000 r-xs 00000000 03:07 993259
/company/workspaces/app/GISappInterface/WEB-INF/lib/dom4j-1.4.jar
afb68000-afc80000 r-xs 00000000 03:07 993254
/company/workspaces/app/GISappInterface/WEB-INF/lib/db2jcc.jar
afc80000-afd05000 r-xs 00000000 03:07 1057567
/company/workspaces/app/GISappWEB/WEB-INF/lib/struts.jar (deleted)
afd0d000-afd12000 r-xs 00000000 03:07 1057481
/company/workspaces/app/GISappWEB/WEB-INF/lib/OtherAppServer.jar
afd12000-afd19000 r-xs 00000000 03:07 992122
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/asm.jar
afd19000-afd48000 r-xs 00000000 03:07 993252
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-net.jar
afd48000-afd51000 r-xs 00000000 03:07 993251
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-logging.jar
afd51000-afd5b000 r-xs 00000000 03:07 993250
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-logging-1.0.4.jar
afd5b000-afd87000 r-xs 00000000 03:07 993249
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-lang.jar
afd87000-afdb1000 r-xs 00000000 03:07 993248
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-lang-2.0.jar
afdb1000-afdcd000 r-xs 00000000 03:07 993246
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-digester.jar
afdcd000-afde4000 r-xs 00000000 03:07 993245
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-digester-1.3.jar
afde4000-afe74000 r-xs 00000000 03:07 993244
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-collections.jar
afe74000-afefd000 r-xs 00000000 03:07 993242
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-collections-3.1.jar
afefd000-aff00000 --xp afefd000 00:00 0
aff00000-aff7e000 rwxp aff00000 00:00 0
aff7e000-aff81000 --xp aff7e000 00:00 0
aff81000-affff000 rwxp aff81000 00:00 0
affff000-b0002000 --xp affff000 00:00 0
b0002000-b0080000 rwxp b0002000 00:00 0
b0080000-b0083000 --xp b0080000 00:00 0
b0083000-b0101000 rwxp b0083000 00:00 0
b0101000-b0104000 --xp b0101000 00:00 0
b0104000-b0182000 rwxp b0104000 00:00 0
b0182000-b0185000 --xp b0182000 00:00 0
b0185000-b0203000 rwxp b0185000 00:00 0
b0203000-b0206000 --xp b0203000 00:00 0
b0206000-b0284000 rwxp b0206000 00:00 0
b0284000-b0287000 --xp b0284000 00:00 0
b0287000-b0305000 rwxp b0287000 00:00 0
b0305000-b0308000 --xp b0305000 00:00 0
b0308000-b0386000 rwxp b0308000 00:00 0
b0386000-b0389000 --xp b0386000 00:00 0
b0389000-b0407000 rwxp b0389000 00:00 0
b0407000-b040a000 --xp b0407000 00:00 0
b040a000-b0488000 rwxp b040a000 00:00 0
b0488000-b048b000 --xp b0488000 00:00 0
b048b000-b0509000 rwxp b048b000 00:00 0
b0509000-b050c000 --xp b0509000 00:00 0
b050c000-b058a000 rwxp b050c000 00:00 0
b058a000-b058d000 --xp b058a000 00:00 0
b058d000-b060b000 rwxp b058d000 00:00 0
b060b000-b060e000 --xp b060b000 00:00 0
b060e000-b068c000 rwxp b060e000 00:00 0
b068c000-b068f000 --xp b068c000 00:00 0
b068f000-b070d000 rwxp b068f000 00:00 0
b070d000-b0710000 --xp b070d000 00:00 0
b0710000-b078e000 rwxp b0710000 00:00 0
b078e000-b0791000 --xp b078e000 00:00 0
b0791000-b080f000 rwxp b0791000 00:00 0
b080f000-b0812000 --xp b080f000 00:00 0
b0812000-b0890000 rwxp b0812000 00:00 0
b0890000-b0893000 --xp b0890000 00:00 0
b0893000-b0911000 rwxp b0893000 00:00 0
b0911000-b0914000 --xp b0911000 00:00 0
b0914000-b0992000 rwxp b0914000 00:00 0
b0992000-b0995000 --xp b0992000 00:00 0
b0995000-b0a13000 rwxp b0995000 00:00 0
b0a13000-b0a16000 --xp b0a13000 00:00 0
b0a16000-b0a94000 rwxp b0a16000 00:00 0
b0a94000-b0a97000 --xp b0a94000 00:00 0
b0a97000-b0b15000 rwxp b0a97000 00:00 0
b0b15000-b0b18000 --xp b0b15000 00:00 0
b0b18000-b0b96000 rwxp b0b18000 00:00 0
b0b96000-b0b99000 --xp b0b96000 00:00 0
b0b99000-b0c17000 rwxp b0b99000 00:00 0
b0c17000-b0c90000 r-xs 00000000 03:07 993276
/company/workspaces/app/GISappInterface/WEB-INF/lib/struts.jar
b0c90000-b0c95000 r-xs 00000000 03:07 992121
/company/workspaces/app/pessoasProcesso/WEB-INF/lib/asm-attrs.jar
b0c95000-b0cb4000 r-xs 00000000 03:07 993239
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-beanutils.jar
b0cb4000-b0cf9000 r-xs 00000000 03:07 993237
/company/workspaces/app/GISappInterface/WEB-INF/lib/cglib-2.1.jar
b0cf9000-b0cfc000 --xp b0cf9000 00:00 0
b0cfc000-b0d7a000 rwxp b0cfc000 00:00 0
b0d7a000-b0d7d000 --xp b0d7a000 00:00 0
b0d7d000-b0dfb000 rwxp b0d7d000 00:00 0
b0dfb000-b0dfe000 --xp b0dfb000 00:00 0
b0dfe000-b0e7c000 rwxp b0dfe000 00:00 0
b0e7c000-b0e7f000 --xp b0e7c000 00:00 0
b0e7f000-b0efd000 rwxp b0e7f000 00:00 0
b0efd000-b0f00000 --xp b0efd000 00:00 0
b0f00000-b0f7e000 rwxp b0f00000 00:00 0
b0f7e000-b0f81000 --xp b0f7e000 00:00 0
b0f81000-b0fff000 rwxp b0f81000 00:00 0
b0fff000-b1002000 --xp b0fff000 00:00 0
b1002000-b1080000 rwxp b1002000 00:00 0
b1080000-b108c000 r-xs 00000000 03:07 993253
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-validator.jar
b108f000-b1090000 rwxp b108f000 00:00 0
b1090000-b1098000 r-xs 00000000 03:07 993258
/company/workspaces/app/GISappInterface/WEB-INF/lib/company-util-0.4.0.jar
b1098000-b10b5000 r-xs 00000000 03:07 993238
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-beanutils-1.6.1.jar
b10b5000-b10b9000 r-xp 00000000 03:03 960039 /lib/libnss_dns-2.5.so
b10b9000-b10ba000 r-xp 00003000 03:03 960039 /lib/libnss_dns-2.5.so
b10ba000-b10bb000 rwxp 00004000 03:03 960039 /lib/libnss_dns-2.5.so
b10bb000-b10bd000 rwxp b10bb000 00:00 0
b10bd000-b10be000 r-xs 00000000 03:07 993277
/company/workspaces/app/GISappInterface/WEB-INF/lib/toggletag.jar
b10be000-b10c6000 r-xs 00000000 03:07 993257
/company/workspaces/app/GISappInterface/WEB-INF/lib/company-license.jar
b10c6000-b10cc000 r-xs 00000000 03:07 993247
/company/workspaces/app/GISappInterface/WEB-INF/lib/commons-fileupload.jar
b10cc000-b10d3000 r-xs 00000000 03:07 993236
/company/workspaces/app/GISappInterface/WEB-INF/lib/asm.jar
b10d3000-b10d6000 --xp b10d3000 00:00 0
b10d6000-b1154000 rwxp b10d6000 00:00 0
b1154000-b1157000 r-xs 00000000 03:07 993256
/company/workspaces/app/GISappInterface/WEB-INF/lib/company-license-0.1.9.jar
b1157000-b115c000 r-xs 00000000 03:07 993235
/company/workspaces/app/GISappInterface/WEB-INF/lib/asm-attrs.jar
b115c000-b11c6000 r-xs 00000000 03:07 993234
/company/workspaces/app/GISappInterface/WEB-INF/lib/antlr-2.7.5H3.jar
b11c6000-b11cb000 r-xs 00000000 03:07 993233
/company/workspaces/app/GISappInterface/WEB-INF/lib/OtherAppServer.jar
b11cb000-b11ce000 --xp b11cb000 00:00 0
b11ce000-b124c000 rwxp b11ce000 00:00 0
b124c000-b124f000 --xp b124c000 00:00 0
b124f000-b12cd000 rwxp b124f000 00:00 0
b12cd000-b12d0000 --xp b12cd000 00:00 0
b12d0000-b134e000 rwxp b12d0000 00:00 0
b134e000-b1372000 r-xs 00000000 03:05 32533
/home2/mapserver/mapscript/mapscript.jar
b1372000-b1386000 r-xp 00000000 03:05 671370
/home2/java/jdk1.5.0_07/jre/lib/i386/libnet.so
b1386000-b1387000 rwxp 00013000 03:05 671370
b1387000-b138c000 r-xs 00000000 03:05 639611
/home2/java/apache-tomcat-5.5.17/server/lib/tomcat-jkstatus-ant.jar
b138c000-b138e000 r-xs 00000000 03:05 639604
/home2/java/apache-tomcat-5.5.17/server/lib/servlets-invoker.jar
b138e000-b13b7000 r-xs 00000000 03:05 639607
/home2/java/apache-tomcat-5.5.17/server/lib/tomcat-ajp.jar
b13b7000-b13bd000 r-xs 00000000 03:05 639595
/home2/java/apache-tomcat-5.5.17/server/lib/catalina-ant-jmx.jar
b13bd000-b13c2000 r-xs 00000000 03:05 639609
/home2/java/apache-tomcat-5.5.17/server/lib/tomcat-coyote.jar
b13c2000-b13df000 r-xs 00000000 03:05 639598
/home2/java/apache-tomcat-5.5.17/server/lib/catalina-optional.jar
b13df000-b147f000 r-xs 00000000 03:05 639600
/home2/java/apache-tomcat-5.5.17/server/lib/catalina.jar
b147f000-b1486000 r-xs 00000000 03:05 639596
/home2/java/apache-tomcat-5.5.17/server/lib/catalina-ant.jar
b1486000-b14c7000 r-xs 00000000 03:05 639612
/home2/java/apache-tomcat-5.5.17/server/lib/tomcat-util.jar
b14c7000-b14d7000 r-xs 00000000 03:05 639599
/home2/java/apache-tomcat-5.5.17/server/lib/catalina-storeconfig.jar
b14d7000-b14ed000 r-xs 00000000 03:05 639610
/home2/java/apache-tomcat-5.5.17/server/lib/tomcat-http.jar
b14ed000-b1520000 r-xs 00000000 03:05 639597
/home2/java/apache-tomcat-5.5.17/server/lib/catalina-cluster.jar
b1520000-b153b000 r-xs 00000000 03:05 639601
/home2/java/apache-tomcat-5.5.17/server/lib/commons-modeler.jar
b153b000-b1541000 r-xs 00000000 03:05 639606
/home2/java/apache-tomcat-5.5.17/server/lib/servlets-webdav.jar
b1541000-b1548000 r-xs 00000000 03:05 639608
/home2/java/apache-tomcat-5.5.17/server/lib/tomcat-apr.jar
b1548000-b154d000 r-xs 00000000 03:05 639603
/home2/java/apache-tomcat-5.5.17/server/lib/servlets-default.jar
b154d000-b155a000 r-xs 00000000 03:05 639590
/home2/java/apache-tomcat-5.5.17/common/lib/jsp-api.jar
b155a000-b155b000 r-xs 00000000 03:05 640464
/home2/java/apache-tomcat-5.5.17/common/lib/db2jcc_license_cu.jar
b155b000-b1581000 r-xs 00000000 03:05 639591
/home2/java/apache-tomcat-5.5.17/common/lib/naming-factory-dbcp.jar
b1581000-b16aa000 r-xs 00000000 03:05 639587
/home2/java/apache-tomcat-5.5.17/common/lib/jasper-compiler-jdt.jar
b16aa000-b16ac000 r-xs 00000000 03:05 640470
/home2/java/apache-tomcat-5.5.17/common/lib/company-login2.jar
b16ac000-b16bf000 r-xs 00000000 03:05 639589
/home2/java/apache-tomcat-5.5.17/common/lib/jasper-runtime.jar
b16bf000-b1741000 r-xs 00000000 03:05 640471
/home2/java/apache-tomcat-5.5.17/common/lib/ifxjdbc.jar
b1741000-b175d000 r-xs 00000000 03:05 639586
/home2/java/apache-tomcat-5.5.17/common/lib/commons-el.jar
b175d000-b1769000 r-xs 00000000 03:05 639593
/home2/java/apache-tomcat-5.5.17/common/lib/naming-resources.jar
b1769000-b1781000 r-xs 00000000 03:05 639594
/home2/java/apache-tomcat-5.5.17/common/lib/servlet-api.jar
b1781000-b17e5000 r-xs 00000000 03:05 639588
/home2/java/apache-tomcat-5.5.17/common/lib/jasper-compiler.jar
b17e5000-b17ef000 r-xs 00000000 03:05 639592
/home2/java/apache-tomcat-5.5.17/common/lib/naming-factory.jar
b17ef000-b1907000 r-xs 00000000 03:05 640462
/home2/java/apache-tomcat-5.5.17/common/lib/db2jcc.jar
b1907000-b1fc1000 r-xs 00000000 03:05 640472
/home2/java/apache-tomcat-5.5.17/common/lib/tools.jar
b1fc1000-b1fc9000 r-xs 00000000 03:05 639584
/home2/java/apache-tomcat-5.5.17/common/i18n/tomcat-i18n-fr.jar
b1fc9000-b1fd2000 r-xs 00000000 03:05 639585
/home2/java/apache-tomcat-5.5.17/common/i18n/tomcat-i18n-ja.jar
b1fd2000-b1fdb000 r-xs 00000000 03:05 639583
/home2/java/apache-tomcat-5.5.17/common/i18n/tomcat-i18n-es.jar
b1fdb000-b1fe5000 r-xs 00000000 03:05 639582
si /home2/java/apache-tomcat-5.5.17/common/i18n/tomcat-i18n-en.jar
b1fe5000-b1fe9000 r-xs 00000000 03:05 639575
/home2/java/apache-tomcat-5.5.17/bin/tomcat-juli.jar
b1fe9000-b1ff0000 r-xs 00000000 03:05 639565
/home2/java/apache-tomcat-5.5.17/bin/commons-logging-api.jar
b1ff0000-b1ff6000 r-xs 00000000 03:05 639561
/home2/java/apache-tomcat-5.5.17/bin/bootstrap.jar
b1ff6000-b1ff8000 r-xs 00000000 03:05 671406
/home2/java/jdk1.5.0_07/jre/lib/ext/dnsns.jar
b1ff8000-b201f000 r-xs 00000000 03:05 671404
/home2/java/jdk1.5.0_07/jre/lib/ext/sunjce_provider.jar
b201f000-b204a000 r-xs 00000000 03:05 671405
/home2/java/jdk1.5.0_07/jre/lib/ext/sunpkcs11.jar
b204a000-b210e000 r-xs 00000000 03:05 671977
/home2/java/jdk1.5.0_07/jre/lib/ext/localedata.jar
b210e000-b210f000 --xp b210e000 00:00 0
b210f000-b218f000 rwxp b210f000 00:00 0
b218f000-b2192000 --xp b218f000 00:00 0
b2192000-b2210000 rwxp b2192000 00:00 0
b2210000-b2213000 --xp b2210000 00:00 0
b2213000-b2291000 rwxp b2213000 00:00 0
b2291000-b2294000 --xp b2291000 00:00 0
b2294000-b2312000 rwxp b2294000 00:00 0
b2312000-b2313000 r-xp 01720000 03:03 230559
/usr/lib/locale/locale-archive
b2313000-b2318000 r-xp 016c4000 03:03 230559
b2318000-b234c000 r-xp 0167a000 03:03 230559
b234c000-b254c000 r-xp 00000000 03:03 230559
b254c000-b254f000 --xp b254c000 00:00 0
b254f000-b25cd000 rwxp b254f000 00:00 0
b25cd000-b25d0000 --xp b25cd000 00:00 0
b25d0000-b264e000 rwxp b25d0000 00:00 0
b264e000-b264f000 --xp b264e000 00:00 0
b264f000-b26e7000 rwxp b264f000 00:00 0
b26e7000-b26fc000 rwxp b26e7000 00:00 0
b26fc000-b2705000 rwxp b26fc000 00:00 0
b2705000-b271a000 rwxp b2705000 00:00 0
b271a000-b271b000 rwxp b271a000 00:00 0
b271b000-b271c000 rwxp b271b000 00:00 0
b271c000-b2725000 rwxp b271c000 00:00 0
b2725000-b273a000 rwxp b2725000 00:00 0
b273a000-b2746000 rwxp b273a000 00:00 0
b2746000-b275a000 rwxp b2746000 00:00 0
b275a000-b2774000 rwxp b275a000 00:00 0
b2774000-b27e5000 rwxp b2774000 00:00 0
b27e5000-b2b8d000 rwxp b27e5000 00:00 0
b2b8d000-b47e5000 rwxp b2b8d000 00:00 0
b47e5000-b5052000 r-xs 00000000 03:05 671976
/home2/java/jdk1.5.0_07/jre/lib/charsets.jar
b5052000-b5067000 r-xs 00000000 03:05 671408
/home2/java/jdk1.5.0_07/jre/lib/jce.jar
b5067000-b50ec000 r-xs 00000000 03:05 671919
/home2/java/jdk1.5.0_07/jre/lib/jsse.jar
b50ec000-b5155000 rwxp b50ec000 00:00 0
b5155000-b7759000 r-xs 00000000 03:05 671998
/home2/java/jdk1.5.0_07/jre/lib/rt.jar
b7759000-b776c000 r-xp 00000000 03:05 671367
/home2/java/jdk1.5.0_07/jre/lib/i386/libzip.so
b776c000-b776e000 rwxp 00012000 03:05 671367
b776e000-b778f000 r-xp 00000000 03:05 671365
/home2/java/jdk1.5.0_07/jre/lib/i386/libjava.so
b778f000-b7791000 rwxp 00020000 03:05 671365
b7791000-b779c000 r-xp 00000000 03:05 671364
/home2/java/jdk1.5.0_07/jre/lib/i386/libverify.so
b779c000-b779d000 rwxp 0000b000 03:05 671364
b779d000-b77a5000 rwxs 00000000 03:03 192030 /tmp/hsperfdata_root/7851
b77a5000-b7b09000 r-xp 00000000 03:05 671358
/home2/java/jdk1.5.0_07/jre/lib/i386/client/libjvm.so
b7b09000-b7b28000 rwxp 00363000 03:05 671358
b7b28000-b7f3f000 rwxp b7b28000 00:00 0
b7f3f000-b7f40000 r-xs 00000000 03:07 993255
/company/workspaces/app/GISappInterface/WEB-INF/lib/db2jcc_license_cu.jar
b7f40000-b7f43000 r-xs 00000000 03:05 639564
/home2/java/apache-tomcat-5.5.17/bin/commons-daemon.jar
b7f43000-b7f4c000 r-xp 00000000 03:03 960041 /lib/libnss_files-2.5.so
b7f4c000-b7f4d000 r-xp 00008000 03:03 960041 /lib/libnss_files-2.5.so
b7f4d000-b7f4e000 rwxp 00009000 03:03 960041 /lib/libnss_files-2.5.so
b7f4e000-b7f54000 r-xp 00000000 03:05 671352
/home2/java/jdk1.5.0_07/jre/lib/i386/native_threads/libhpi.so
b7f54000-b7f55000 rwxp 00006000 03:05 671352
b7f55000-b7f56000 rwxp b7f55000 00:00 0
b7f56000-b7f57000 r-xp b7f56000 00:00 0
b7f57000-b7f58000 rwxp b7f57000 00:00 0
b7f58000-b7f59000 r-xp b7f58000 00:00 0 [vdso]
bfad5000-bfad8000 --xp bfad5000 00:00 0
bfad8000-bfcd5000 rwxp bfad8000 00:00 0 [stack]
VM Arguments:
jvm_args:
-Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
-Djava.util.logging.config.file=/usr/java/tomcat/conf/logging.properties
-Djava.endorsed.dirs=/usr/java/tomcat/common/endorsed
-Djava.security.manager
-Djava.security.auth.login.config=/usr/java/tomcat/conf/jaas.config
-Djava.security.policy==/usr/java/tomcat/conf/catalina.policy
-Dcatalina.base=/usr/java/tomcat -Dcatalina.home=/usr/java/tomcat
-Djava.io.tmpdir=/usr/java/tomcat/temp
java_command: org.apache.catalina.startup.Bootstrap start
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/usr/java/jdk
JRE_HOME=/usr/java/jre
CLASSPATH=:/usr/java/tomcat/bin/bootstrap.jar:/usr/java/tomcat/bin/commons-logging-api.jar
PATH=/usr/lib/qt-3.3/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/java/jre/bin:/usr/java/jdk/bin:/home2/mapserver/mapscript:/root/bin
LD_LIBRARY_PATH=/home2/java/jdk1.5.0_07/jre/lib/i386/client:/home2/java/jdk1.5.0_07/jre/lib/i386:/home2/java/jdk1.5.0_07/jre/../lib/i386:::/home2/mapserver/proj4/lib:/home2/mapserver/gdal/lib:/home2/mapserver/geos/lib:/home2/mapserver/libcurl/lib:/home2/mapserver/libpng/lib:/home2/mapserver/libjpeg/lib:/home2/mapserver/libtiff/lib:/home2/mapserver/libgeotiff/lib:/home2/mapserver/ogdi/lib:/home2/mapserver/freetype/lib:/home2/mapserver/gd/lib:/home2/mapserver/zlib/lib:/home2/mapserver/proj4/share/proj:/home2/mapserver/mapscript:/home2/mapserver/proj4/lib:/home2/mapserver/gdal/lib:/home2/mapserver/geos/lib:/home2/mapserver/libcurl/lib:/home2/mapserver/libpng/lib:/home2/mapserver/libjpeg/lib:/home2/mapserver/libtiff/lib:/home2/mapserver/libgeotiff/lib:/home2/mapserver/ogdi/lib:/home2/mapserver/freetype/lib:/home2/mapserver/gd/lib:/home2/mapserver/zlib/lib:/home2/mapserver/proj4/share/proj
SHELL=/bin/bash
DISPLAY=:0
Signal Handlers:
SIGSEGV: [libjvm.so+0x31fae0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x31fae0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x2852b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x2852b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x2852b0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x287700], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x287130], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x287130], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x287130], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x287130], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:Fedora Core release 6 (Zod)
uname:Linux 2.6.18-1.2798.fc6 #1 SMP Mon Oct 16 14:54:20 EDT 2006 i686
libc:glibc 2.5 NPTL 2.5
rlimit: STACK 10240k, CORE 0k, NPROC 7935, NOFILE 1024, AS infinity
load average:2.67 1.54 0.82
CPU:total 1 family 6, cmov, cx8, fxsr, mmx, sse
Memory: 4k page, physical 498976k(21720k free), swap 522072k(473592k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_07-b03) for linux-x86, built
on May 3 2006 01:46:28 by java_re with gcc 3.2.1-7a (J2SE release)
