Tiled datasets with OGR
Daniel Morissette
dmorissette at MAPGEARS.COM
Thu Mar 29 14:00:36 EDT 2007
Um... not sure why the STYLEITEM AUTO would not work with a tiled OGR
layer, but anyway, a workaround for this issue would be to convert your
tiled TAB files to a Seamless TAB Dataset using MapInfo. Seamless Tables
are similar to tiled dataset, but the tiling is handled in the MapInfo
driver inside OGR so MapServer sees the seamless table as a single
MapInfo file. Then you'd just point to the seamless table (.tab file) in
the CONNECTION string and STYLEITEM AUTO should work.
Daniel
Roland Martin wrote:
> Hi,
> I'm having a bit of trouble with a tiled dataset - I suspect there's a
> number of things at play, so I'll phrase this as a question!
> Is it possible to tile MapInfo TABs; display them as a single layer in
> MapServer; and still use 'STYLEITEM AUTO'?
> I've managed the first 2 without any problems, by storing the tiles as a
> shapefile, but the styling wasn't working ("not available for this
> datasource" or somesuch). I then tried using a TAB as the TILEINDEX, but
> that didn't seem to be working at all (not clear if this was a MapServer
> or OGR problem though).
> So, am I missing something here, or is it not possible?
> Thanks for your help,
> Roland.
Daniel Morissette
http://www.mapgears.com/
