issue with classitem and tileindex...
John Cole
john.cole at UAI.COM
Thu Mar 29 14:51:05 EDT 2007
I have a couple of county shapefiles where I've created a tileindex using
tile4ms. When I render these with MS, things work fine until I set the
classitem, and then it can't find the classitem column on the shapefile (in
this case 'cfcc').
Is there something special you have to do to use a class item or label item
with a tileindex?
Thanks,
John
View this message in context: http://www.nabble.com/issue-with-classitem-and-tileindex...-tf3488200.html#a9740262
Sent from the Mapserver - User mailing list archive at Nabble.com.
