issue with classitem and tileindex...
John Cole john.cole at UAI.COM
Thu Mar 29 16:04:19 EDT 2007
Steve,
  Thanks for the quick reply, unfortunately I had already tried that :-(
msDBFGetItemIndex(): DBASE file error. Item 'CFCC' not found.
Is there anything else that could be wrong?
Here is my layer:
	LAYER
		NAME "landmark_polys"
		GROUP "bound"
		TILEINDEX "lpy_idx"
        METADATA
			"wms_title" "landmark_polys"
			"wms_group_title" "landmark"
		END
		PROJECTION
			"init=epsg:4326"
		END
		STATUS ON
		CLASSITEM "CFCC"
		TYPE POLYGON
		CLASS
			EXPRESSION "D82"
			NAME 'Cemetary'
			MAXSCALE 250000
			STYLE
				COLOR 209 208 204
			END
		END
END
We are using the current version of MS4W.
Thanks,
John
Stephen Woodbridge wrote:
> John,
> In shapefiles attribute are all upper case. try:
>     classitem 'CFCC'
> -Steve W
> John Cole wrote:
>> I have a couple of county shapefiles where I've created a tileindex using
>> tile4ms.  When I render these with MS, things work fine until I set the
>> classitem, and then it can't find the classitem column on the shapefile
>> (in
>> this case 'cfcc').
>> Is there something special you have to do to use a class item or label
>> item
>> with a tileindex?
>> Thanks,
>> John
View this message in context: http://www.nabble.com/issue-with-classitem-and-tileindex...-tf3488200.html#a9741591
Sent from the Mapserver - User mailing list archive at Nabble.com.
