issue with classitem and tileindex...
John Cole
john.cole at UAI.COM
Thu Mar 29 17:21:47 EDT 2007
Brent,
Well, I didn't know about the 'newer' method. I got it working similar to
the 'old' one but it still doesn't recognize the 'CFCC' column when I add
the class item.
Thanks,
John
Brent Fraser wrote:
> John,
> You could try the newer (and more flexible?) "two-layer"
> style of tileindex specification:
> LAYER
> NAME "lpy_idx_lyr"
> TYPE TILEINDEX
> DATA "lpy_idx"
> END
> LAYER
> NAME "landmark_polys"
> GROUP "bound"
> TILEINDEX "lpy_idx_lyr" # this points to the above layer
> METADATA
> "wms_title" "landmark_polys"
> "wms_group_title" "landmark"
> END
> PROJECTION
> "init=epsg:4326"
> END
> STATUS ON
> CLASSITEM "CFCC"
> CLASS
> EXPRESSION "D82"
> NAME 'Cemetary'
> MAXSCALE 250000
> STYLE
> COLOR 209 208 204
> END
> END
> END
> I haven't tested this, so it may not work. The trick is to
> tell Mapserver the CLASS is to be applied to the files
> pointed to by the tileindex, not the tile index itself (I'm
> sure it doesn't have an attributed named "CFCC").
> Steve Woodbridge may have some insight into this, since it's
> tiled vectors; I've only done tiled raster....
> Brent Fraser
> GeoAnalytic Inc.
> Calgary, Alberta
> ----- Original Message -----
> From: "John Cole" <john.cole at UAI.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Thursday, March 29, 2007 2:04 PM
> Subject: Re: [UMN_MAPSERVER-USERS] issue with classitem and
> tileindex...
>> Steve,
>> Thanks for the quick reply, unfortunately I had already
> tried that :-(
>> msDBFGetItemIndex(): DBASE file error. Item 'CFCC' not
> found.
>> Is there anything else that could be wrong?
>> Here is my layer:
>> LAYER
>> GROUP "bound"
>> TILEINDEX "lpy_idx"
>> METADATA
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> STATUS ON
>> CLASSITEM "CFCC"
>> TYPE POLYGON
>> CLASS
>> EXPRESSION "D82"
>> NAME 'Cemetary'
>> MAXSCALE 250000
>> STYLE
>> COLOR 209 208 204
>> END
>> END
>> END
>> We are using the current version of MS4W.
>> Thanks,
>> John
>> Stephen Woodbridge wrote:
>> > John,
>> > In shapefiles attribute are all upper case. try:
>> > classitem 'CFCC'
>> > -Steve W
>> > John Cole wrote:
>> >> I have a couple of county shapefiles where I've created
> a tileindex using
>> >> tile4ms. When I render these with MS, things work fine
> until I set the
>> >> classitem, and then it can't find the classitem column
> on the shapefile
>> >> (in
>> >> this case 'cfcc').
>> >> Is there something special you have to do to use a
> class item or label
>> >> item
>> >> with a tileindex?
>> >> Thanks,
>> >> John
>> View this message in context:
> http://www.nabble.com/issue-with-classitem-and-tileindex...-tf3488200.html#a9741591
>> Sent from the Mapserver - User mailing list archive at
> Nabble.com.
View this message in context: http://www.nabble.com/issue-with-classitem-and-tileindex...-tf3488200.html#a9742947
Sent from the Mapserver - User mailing list archive at Nabble.com.
