MapScript Java problem
Houde, Jonathan JHoude at KOREM.COM
Fri Mar 30 12:38:58 EDT 2007
I'm trying to make MapScript java work under tomcat 5.5.17 / jdk 6.0 /
windows xp
And I'm getting the following error:
java.lang.UnsatisfiedLinkError: C:\mapscript\mapscript.dll: The
operating system cannot run %1
I already included the following folder in the path system variable
C:\ms4w\Apache\cgi-bin
C:\ms4w\Apache\cgi-bin\mapscript\java
As well as the proj lib variable.
PROJ_LIB
C:\ms4w\proj\nad
The package I installed is from ms4w_2.2.3.zip
I have tried several variation of my setup including change of jdk to
5.0 and I keep getting that error...
I know that the actual dlls are found in the path since when I remove
one folder from the path variable I receive either,
UnsatisfiedLinkError: C:\mapscript\mapscript.dll, ddl not in the
java.library.path
Or
Dll dependency not found in the java.library.path
This seems to be related with dll version mismatch.
For example:
http://support.borland.com/entry.jspa?externalID=6065&categoryID=447
Any ideas?
Thanks,
Jonathan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070330/8dc413dc/attachment.html
