Help: SDE error. SE_layer_get_info(): Layer not found. (-20)
Sun, Xijiang XIJIANG.SUN at SAIC.COM
Fri Mar 30 16:32:18 EDT 2007
I Solved this problem by myself.
Rewrite the connection string, full computer name and no space between. Now it solved the problem.
Thanks and Regards,
Sun
-----Original Message-----
From: Sun, Xijiang [mailto:XIJIANG.SUN at saic.com]
Sent: Fri 3/30/2007 3:57 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: FW: Help:  SDE error. SE_layer_get_info(): Layer not found. (-20)
Dear folks,
I am using the MapServer 4.10.1, the data source is from ArcSDE 9.1 for Oracle.
My settings is like below:
		NAME 'GDT.SDE_BAY_ZIPI'
		GROUP 'GDT.SDE_BAY_ZIPI'
		CONNECTIONTYPE sde
		#CONNECTION 'SunServer,5151,sde,ps,ps'
		CONNECTION "SunServer,port:5151,sde,ps,ps"
		DATA "GDT.SDE_BAY_ZIPI, SHAPE"
		#DATA "GDT.SDE_BAY_ZIPI, SHAPE, SDE.DEFAULT"
Now I get message like below:
msDrawMap(): Image handling error. Failed to draw layer named 'GDT.SDE_BAY_ZIPI'.
msSDELayerOpen(): SDE error. SE_layer_get_info(): . (1)
msSDEGetLayerInfo(): SDE error. SE_layer_get_info(): Layer not found. (-20)
CGI Request 1 on process 5032 msDrawMap(): Layer 0 (GDT.SDE_BAY_ZIP), 0.020s
Another interesting thing is that I can not specify "SDE.DEFAULT".
if I use setting like below.
When I am using
I got the following error.
msSDELayerOpen(): SDE error. SE_version_get_info(): Version not found. (-126)
CGI Request 1 on process 4676 msDrawMap(): Layer 0 (GDT.SDE_BAY_ZIP), 0.010s
The data connection looks correct. I am able to view the same data through ArcCatalog.   Any hint to help me continue my work?
Thanks a lot.
Have a great weekend.
Sun
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070330/b9e8dbb6/attachment.html
