Ack! Labelling numeric fields bug.
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue May 1 20:32:17 EDT 2007
I have a shapefile, actually 10s of thousands of shapefiles that have
contour lines and I want to label them. The problem is that they are
defined as:
15. ELEVATION N 31 15
and when a use this field to label my map, mapserver zero fills the
field out to 15 digits of zeros!!! So a value of 10 in the field gets
labeled as 10.000000000000000
I think this is a little extreme! :) OK, it is kind of cool to see these
long snakes follow the contour if I use ANGLE FOLLOW.
I will open a bug for this, but any thoughts in a short term work around?
-Steve W
