WMS: non square pixels performance
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Thu May 3 02:01:37 EDT 2007
Hi Frank,
I've tested your change and the speedup is really big. Thanks.
I've opened up ticket 2084 for this:
http://trac.osgeo.org/mapserver/ticket/2084
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Frank Warmerdam <warmerdam at POBOX.COM>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-USERS] WMS: non square pixels performance
Datum: 02/05/07 19:08
> Eijnden, Bart van den (AGI) wrote:
> > Hi Frank,
> > the data (shape file) can be downloaded from here (about 20 Mb):
> Bart,
> Whew, that is a big slow down! It seems that the projection you are using
> is very expensive computationally, and it was being applied twice per
> point unecessarily so that the rescaling needed for non-square pixels
could
> be applied.
> I have applied a change in mapproject.c to short circuit this reprojection
> work that brings down the slow case to only about 50% more time than the
> fast case. If you can easily test with trunk or perhaps incorporate this
> change into the source you are building from that would be appreciated.
> http://trac.osgeo.org/mapserver/changeset/6075
> If it works well for you, I'd be inclined to incorporate this fix into
> MapServer 4.10.2 but I'll need a ticket in trac to reference.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
