Change of Data Source changes Mapserver behavior
Matt Pettis
matt.pettis at THOMSON.COM
Fri May 4 00:50:45 EDT 2007
This worked great -- thanks a ton!
Matt
-----Original Message-----
From: Aaron Racicot [mailto:aaronr at z-pulley.com]
Sent: Thu 5/3/2007 10:30 PM
To: Pettis, Matthew (Thomson); MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] Change of Data Source changes Mapserver behavior
Hey there Matt,
Try:
1) Comment out your data statement for shapefile
2) Uncomment your three lines for PostGIS
3) Modify your data statement to be just [1]:
DATA "the_geom from shp_counties"
4) If you need to have the more complex query [2] in the future for things
like sub-selects, then I believe you need a unique id in the " using unique
the_geom" part of your query. Usually people use OID.
Hope that helps...
A
[1] - http://postgis.refractions.net/docs/ch04.html#id2893813
[2] - http://postgis.refractions.net/docs/ch04.html#id2894254
Aaron Racicot - GIS Programmer
360.221.2441 - aaronr at ecotrust.org
e c o t r u s t
pobox 1614
langley wa 98260
www.ecotrust.org
________________________________________
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Matt Pettis
Sent: Thursday, May 03, 2007 8:00 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Change of Data Source changes Mapserver
behavior
The map file at the end of this post is used by me to create a client-side
image map. When I call this map file using a data source of .shp files
(which happens when SHAPEPATH and the 'NAME "counties"' lines are
uncommented), I get the proper result back to the calling webpage. When
those lines are commented out and I instead use the lines that begin:
CONNECTION ...
CONNECTIONTYPE ...
DATA ...
to retrieve the same date from a POSTGIS/POSTGRESQL database, I don't get
the right results. The following is a snippet of what I do get returned:
Content-type: text/html
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS
SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG -->
<BODY BGCOLOR="#FFFFFF">
</BODY></HTML>
Can anybody answer why the behavior changes when all i do is change the
datasource? the shapefile and the table are the same (well, except for
whatever changes when I use the postgis tools to load the shapefile into the
Postgresql table, which should be only data format). Does anybody know how
to fix/work around this?
Thanks!
Matt
=== map.map ===
MAP
IMAGETYPE PNG
EXTENT 189783.546875 4810309 761653.5625 5472346.5
SIZE 680 510
SHAPEPATH "C:\ms4w\gisvote\data\shp"
IMAGECOLOR 255 255 255
WEB
# HEADER "imgmap-th.htm"
# FOOTER "imgmap-tf.htm"
# TEMPLATE "imgmap-t.htm"
IMAGEPATH "C:\ms4w\Apache\htdocs\tmp\"
IMAGEURL "/tmp/"
END
QUERYMAP
STATUS ON
STYLE NORMAL
END
LAYER
NAME "counties"
### this is pulling straight from the .shp files
DATA "counties"
### or...
### this does not behave like calling info from shape files... i don't know
why yet
### when using this, probably don't need the SHAPEPATH setting.
# CONNECTION "user=postgres dbname=postgis password=4theluv"
# CONNECTIONTYPE POSTGIS
# DATA "the_geom from (select * from shp_counties) as foo using unique
the_geom using SRID=-1"
STATUS DEFAULT
TYPE POLYGON
CLASS
NAME "county_class"
STYLE
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
END
It is from the wellspring of our despair and the places that we are broken
that we come to repair the world.
-- Murray Waas
