Retrieve data from Deegree WFS
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Fri May 4 04:43:11 EDT 2007
This layer works fine for me with Geoserver WFS v. 1.0
Regards,
-Jukka-
LAYER
NAME "WFS-parcels"
STATUS OFF
TYPE POLYGON
CONNECTIONTYPE WFS
CONNECTION "http://localhost:8080/geoserver/wfs?"
MAXSCALE 100000
PROJECTION
"init=epsg:2393"
END
CLASS
NAME "parcels"
STYLE
OUTLINECOLOR 0 255 0
END
END
METADATA
"wfs_service" "WFS"
"wfs_typename" "GIS_PARCELS"
"wfs_version" "1.0.0"
"wfs_request_method" "GET"
"wfs_connectiontimeout" "300"
"wfs_maxfeatures" "100000"
"gml_include_items" "all"
END
TEMPLATE "../../../../../../..//ms101/data/query.html"
dump true
# DEBUG TRUE
END
Lähettäjä: UMN MapServer Users List puolesta: Anna Zanetti
Lähetetty: to 3.5.2007 13:52
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: [UMN_MAPSERVER-USERS] Retrieve data from Deegree WFS
Hi to all,
I'm very new of MapServer. I'm interesting in the possibility of MapServer
of taking another WFS as a data source. I follow the guide but I have only
found examples with WFS implemented with MapServer itself and not others
like Deegree or GeoServer.
Does this mean that it is possible to use only MapServer WFS as data source
or I can use other services? In this case, could you please send me the
parameters for the string connection????
I have tried to use Deegree WFS, but MapServer says that it is not able to
draw the layer. Maybe it depends on the version of WFS that MapServer
supports (1.0.0) while Deegree supports (1.1.0).
Thanks a lot for your help.
Best regards
Anna Zanetti
View this message in context: http://www.nabble.com/Retrieve-data-from-Deegree-WFS-tf3685769.html#a10302541
Sent from the Mapserver - User mailing list archive at Nabble.com.
