Define Map Extent for small area
Matthew Perry
perrygeo at GMAIL.COM
Sat May 5 12:30:03 EDT 2007
Amal,
Can you confirm that your shapefile is in geographic (lat/long) coordinates?
If not you'll have to set up a PROJECTION object for the map and layer.
- matt
On 5/4/07, AMAL OMAR <amal_osaad2003 at yahoo.com> wrote:
> Hi ,
> I have been create map file for small area about 1km2,but the problem , it
> can not get the vector map for my area, the map output come white no data
> present.
> Degree Minutes Seconds (DMS) for shape file is
> (13° 11'4.0",
> 13°11'13.2") west
> (32° 52'5.9", 32°
> 52'26.2") North
> I have changed it to decimal Degree (DD):
> Xmin=13.184444
> Ymin=32.86306
> Xmax=13.187000
> Ymax=32.873944
> The map file code:
> # This is our first mapfile
> NAME "first-cis"
> UNITS dd
> SIZE 400 300
> IMAGECOLOR 255 255 255
> IMAGETYPE PNG
> SHAPEPATH "/ms4w/home/mapdata/cis/"
> EXTENT 13.184444 32.86306 13.187000 32.873944
> WEB
> TEMPLATE '/ms4w/var/www/htdocs/cis/first-cis.html'
> IMAGEPATH '/ms4w/var/www/htdocs/tmp/'
> IMAGEURL '/tmp/'
> END
> LAYER
> NAME "Azwia Hospital"
> STATUS default
> TYPE polygon
> DATA "hospital"
> CLASS
> STYLE
> COLOR 255 0 0
> END
> END
> END
> END
> HTML File:
> <html>
> <head> <title>MapServer First cadastral Map</title></head>
> <body>
> <form method=POST action="/cgi-bin/mapserv.exe" id=form1 name=form1>
> <input type="submit" value="Click Me" id=submit1 name=submit1>
> <input type="hidden" name="map"
> value="/ms4w/home/mapdata/cis/first-cis.map">
> <input type="hidden" name="map_web_imagepath"
> value="/ms4w/var/www/htdocs/tmp/">
> </form>
> <IMG SRC="[img]" width=400 height=300 border=0>
> </body>
> </html>
> ________________________________
> Get your own web address.
> Have a HUGE year through Yahoo! Small Business.
Matthew T. Perry
http://www.perrygeo.net
"You never change things by fighting the existing reality.
To change something, build a new model that makes
the existing model obsolete" - R. Buckminster Fuller
