queryable layer
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Tue May 8 04:33:13 EDT 2007
This is not considered a bug.
For 5.0 there is talk about introducing a QUERYABLE keyword instead (with
values true/false).
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Barend Köbben <kobben at ITC.NL>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-USERS] queryable layer
Datum: 08/05/07 05:40
> I noticed this and asked about it some time ago, if it is considered a
bug..
> Is it?
> __
> Barend Köbben
> International Institute for Geo-information
> Sciences and Earth Observation (ITC)
> PO Box 6, 7500AA Enschede (The Netherlands)
> ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> On 08-05-2007 03:34, "Steve Lime"
<Steve.Lime at DNR.STATE.MN.US> wrote:
> > Queryable layers need a presentation template defined regardless if
it
> > will be used (e.g. TEMPLATE 'foo.html'). This is true for CGI and
WxS.
> > Steve
> >>>> Giuseppe De Rossi <giuseppe.derossi at EMAIL.IT>
05/05/07 11:40 AM >>>
> > Hi all,
> > I'm trying to implement a quaryable layer . The data are stored in
three
> > files .shp .shp and dbf. In the last one there is the following
> > structure:
> > ADMAPKEY(int) , CENTER(string) , MYTEXT (string)
> > 1 , 70282.3193,-20782.0280,this is a point of interest
> > I've added the following Layer in the .map file:
> > LAYER
> > NAME "Pointofint"
> > STATUS ON
> > DATA "Pointofint"
> > TEMPLATE "ttt"
> > TYPE POINT
> > UNITS METERS
> > SIZEUNITS PIXELS
> > LABELITEM "MYTEXT"
> > METADATA
> > "exported_values"
"recenter_name_string,id_attribute_string"
> > "id_attribute_string" "ADMAPKEY"
> > "query_returned_attributes" "MYTEXT"
> > END
> > CLASS
> > NAME "Pointofint"
> > STYLE
> > SYMBOL "circle"
> > COLOR 255 0 0
> > OUTLINECOLOR 0 0 0
> > SIZE 20
> > END
> > END
> > END
> > I can see the layer but unfortunately no data has been returned . Is
it
> > correct the layer definition ?
> > How can I check the chain to see where is the broken ring ?
> > Thanks in advantage and best regards
> > Giu
> > Email.it, the professional e-mail, gratis per te:
http://www.email.it/f
> > Sponsor:
> > Logos Finanziaria SPA. Società di credito ad erogazione diretta.
Fino a
> > 30.000 euro in 24 ore! Clicca e scopri come
> > Clicca qui:
http://adv.email.it/cgi-bin/foclick.cgi?mid=2909&d=20070505
