changing name for generated maps in ms_tmp directory
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed May 9 23:31:21 EDT 2007
I would use shp2img to do this. It doesn't sound like you need to use the CGI because there is nothing dynamic. Could also write a simple script to do it. With shp2img or a script you have total control over the output names.
Steve
(BTW the unique id is generated for sure in the CGI (mapserv.c) and perhaps MapScript has that ability, that I'm not sure about though.)
>>> Malte <MalteAhrens at ARCOR.DE> 05/09/07 9:06 AM >>>
I'm building a very simple, static webpage with images (200+) generetad
through mapserver. These images are not located on the same machine as they
were generated - to link the images I need mapserver to write the maps with
a predefined name (instead of
474d54c78eb892c470ef5e0959b056bb1178630666076768600.png).
Example:
3 Layers: wood.shp,water.shp,mountain.shp (defined in Mapfile)
The name of the images in the image-tmp directory created by Mapserver
should be wood.png, water.png, mountain.png, so i can reference them in my
static webpage.
Can somebody give me a hint to solve this problem? Where is the random name
generated and how to tell the mapserver to produce images with the name of
the shapefile?
with king regards,
Malte
View this message in context: http://www.nabble.com/changing-name-for-generated-maps-in-ms_tmp-directory-tf3715971.html#a10395010
Sent from the Mapserver - User mailing list archive at Nabble.com.
