Structuring rasters?
Jeff Dege
jdege at KORTERRA.COM
Fri May 18 15:47:02 EDT 2007
We have a customer who wants to integrate aerial photos into their maps.
The extent of the map is that of a middle-sized state. 200-400
kilometers.
The tightest zoom is a couple of blocks. 100-200 meters.
(Map size scales with the browser - figure 600-800 pixels.)
I've done a bit of playing around with the GDAL tools with a
county-level dataset. From this I learned that:
1. You can futz around with this stuff forever, never getting it quite
right.
2. You're chunking enough data that every failed attempt takes forever.
The question is, given a few tens of thousands of hi-res jpegs, what is
the best way to restructure them so as to give acceptable performance
through Mapserver?
