[UMN_MA PSERVER-USERS] Mutiple "DATA " lines in a single l ayer?
Jeff Dege jdege at KORTERRA.COM
Fri May 18 17:22:54 EDT 2007
> -----Original Message-----
> From: Matthew Perry [mailto:perrygeo at gmail.com]
> Sent: Friday, May 18, 2007 4:07 PM
> To: Jeff Dege
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] RE : [UMN_MA
> Jeff,
>  If you're looking to dynamically change the DATA element of a layer,
> you should check out variable substitution
> (http://mapserver.gis.umn.edu/docs/reference/mapfile/variable_sub) .
> No mapscript required.
That may well be the answer I was looking for.
Thanks.
