WFS: Problems with multipolygons
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon May 21 14:31:31 EDT 2007
What version of MapServer are we talking about here? There were some problems with
certain multi-part features in older version of MapServer (I don't recall exact version numbers
but can check). I believe Bart identified a test case that the fix was based on. The problem
was in the GML encoder. 4.10.3 should be fine.
Steve
>>> On 5/20/2007 at 10:15 PM, in message <46510EBC.9030808 at univali.br>, Fernando
Simon <fsimon at UNIVALI.BR> wrote:
> Hi Teemu,
> Sorry for the delay to reply you message.
> About this error, did you already tried to draw a map in CGI mode,
> just to test all the polygons? Dis you already try to restrict the
> objects in the data definition. Like: "GEOLOC FROM (SELECT ID_X, GEOLOC
> TABLE_X WHERE ID_X = XXXXX) USING UNIQUE ID_X". Where the XXXXX is the
> id for the object that are not draw?
> About the objects, all have the same attributes, like SRID, GTYPE
> and ETYPE?
> I'm a not WFS specialist, I believe that the Bart can help in this
> way, I can help with the Oracle relate issues.
> Best regards.
> Fernando Simon
> UMN Mapserver and Oracle Spatial developer
> Teemu Makela wrote:
>> More information related to this issues.
>> I tested the same layer through WMS and WFS. Layer works fine through WMS
>> but WFS omits all execpt one part of the multipolygon. At below you will
>> also find the mapfiles.
>> See attached image "MapServer_WMS" which contains a multipolygon (5 parts
>> with label 10404).
>> See another attached image "MapServer_WFS_missing_polygons_labels_from_WMS".
>> On this image only one piece of the multipolygon is visible. Labels are from
>> WMS layer just to show that there should be more data (label is variable
>> ID_X from mapfiles).
>> Is it so that MapServer's WFS just cannot handle multipolygons or am I doing
>> something wrong?
>> ---- Mapfiles ----
>> WMS layer drawing polygons:
>> LAYER
>> NAME XXXXXX
>> TYPE POLYGON
>> STATUS ON
>> CONNECTIONTYPE oraclespatial
>> CONNECTION "xxx/xxx at xxx.xxx.com"
>> DATA "GEOLOC FROM TABLE_X USING UNIQUE ID_X"
>> PROJECTION
>> "init=epsg:2393"
>> END
>> CLASS
>> NAME "GEOMETRIA"
>> STYLE
>> OUTLINECOLOR 200 200 200
>> COLOR 255 0 0
>> END
>> END
>> END
>> WFS layer trying to draw polygons:
>> LAYER
>> NAME XXXXXX
>> METADATA
>> "wfs_title" "XXXXXXXX"
>> "wfs_extent" "XXX XXX XXX XXX"
>> "gml_featureid" "ID_X"
>> "gml_include_items" "all"
>> END
>> TYPE POLYGON
>> STATUS ON
>> PROJECTION
>> "init=epsg:2393"
>> END
>> DUMP TRUE
>> CLASS
>> NAME "GEOMETRIA"
>> STYLE
>> END
>> END
>> END
>> Teemu
