Too many open files on mapserv 4.10.1
Rodrigo Del C. Andrade
rodrigo.andrade at DIGITRO.COM.BR
Tue May 22 10:55:59 EDT 2007
I am way too swamped right now to fill a bug report, but check in
the INCLUDES on your mapfile.
I have this problem on 4.10.1 and the culprit was the includes I had
on my main mapfile being left open.
Cheers,
*Rodrigo Del C. Andrade*
/Programador/
/SIC - SSE - Soluções Segurança Pública/
*DÍGITRO TECNOLOGIA*
*E-mail:* rodrigo.andrade at digitro.com.br
<mailto:rodrigo.andrade at digitro.com.br>
*Fone:* +55 48 3281-7314 / +55 48 3281-7000
*Fax:* +55 48 3281-7299
*Site:* www.digitro.com <http://www.digitro.com>
Daniel Morissette wrote:
> Sorry for the late reply. That sounds like a leak of file handles,
> perhaps you could use 'lsof' to find out which files are left open
> (you'd have to do that before the script ends execution), and then
> file a bug with all the details.
> Daniel
> Benedito A. Cruz wrote:
>> Hello,
>> I am upgrading my mapserv applications to a new server. It starts
>> working
>> with no problems, but after a while the mapserv application stops
>> working.
>> After a lot of tests i discovered that the following Perl program
>> works OK
>> using mapserv 4.2.0 in the old server , but returns with "Too many open
>> files" using mapserv 4.10.1 in the new server (it opens 23 files and
>> die):
>> #!/usr/local/bin/perl
>> $|=1;
>> use mapscript;
>> foreach (0..50)
>> { print "$_ ";
>> my $map = new
>> mapscript::mapObj('/home/mapcria/bin/data/mapfiles/default.map') or die
>> "Unable to open mapfile $!";
>> undef $map;
>> $./tooManyOpenFilesBug 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
>> 19 20 21 22 Unable to open
>> mapfile Too many open files at /home/xxx/tooManyOpenFilesBug
>> Does anybody have a hint on the problem? I need it opening a lot of
>> files,
>> since I am using mapserv as a component of a web service and not as a
>> CGI.
>> The versions I am using in the new server are:
>> Fedora Core 6 x86_64
>> Kernel 2.6.18-1.2798.fc6 x86_64 x86_64 x86_64 GNU/Linux
>> GCC 4.1.1 20070105 (Red Hat 4.1.1-51)
>> PERL 5.8.8
>> GDAL 1.4.0
>> GD 2.0.33
>> GEOS 2.2.3
>> GEOTIFF 1.2.3
>> PROJ 4.5.0
>> []s
>> Benê
