Problem with layer.getExtent() and Oracle (MapScript Java)
Fernando Simon fsimon at UNIVALI.BR
Mon May 28 08:32:01 EDT 2007
Hi Arkadi Shishlov,
    I believe that the error is relate with your Data string.
    Just few questions, why are you using "null" and "1=1"? Any special
issue? What version of Oracle are you using? 8i? 9i? 10g?
    I suggest you to use this: (and add the version in the end)
      sqlMapserverQuery = "L82GEOMETRY from (select L82GEOMETRY,
DATASET82ID, L82C23T1, L82C12T1, L82C20T1, L82C24T1, L82C22T1, L82C21T1
from DATASET82) USING UNIQUE DATASET82ID SRID 3059 VERSION 9i"
    Best regards.
Fernando Simon
UMN Mapserver and Oracle Spatial developer
Arkadi Shishlov wrote:
> Calling extent = layer.getExtent() on the Oracle based layer returns rectObj with all components set to -1
> extent => { 'minx': -1 , 'miny': -1 , 'maxx': -1 , 'maxy': -1 }
> The layer is created by
> sqlMapserverQuery = "L82GEOMETRY from (select null, L82GEOMETRY, DATASET82ID, L82C23T1, L82C12T1, L82C20T1, L82C24T1, L82C22T1, L82C21T1 from DATASET82 where 1 = 1) USING UNIQUE DATASET82ID SRID 3059"
> layer.setStatus(mapscriptConstants.MS_ON);
> //layer.setType(MS_LAYER_TYPE.MS_LAYER_ANNOTATION);
> layer.setType(MS_LAYER_TYPE.MS_LAYER_POINT);
> layer.setConnectiontype(MS_CONNECTION_TYPE.MS_ORACLESPATIAL);
> layer.setConnection(mapDataConnectionString);
> layer.setData(sqlMapserverQuery);
> layer.setStatus(visible ? 1 : 0);
> layer.setTemplate("any.html");
> layer.setProjection(dbProjection);
> I can sucessfully retrieve extent of SHP based layers. Also many other operations on the above mentioned Oracle layer works just fine.
> I'm using Mapserver 4.10.1 from MS4W 2.2.3 on Windows XP, Sun Java 1.5.0_09, Tomcat 5.5.20.
> Any hints? Is it a bug in my application or Mapserver?
