turn layer labels on and off dynamically
Gregor Mosheh
gregor at HOSTGIS.COM
Tue May 29 23:06:00 EDT 2007
> I am using the Java MapScript for my application and I would like to
> present the option for the user to decide whether or not to show labels
> for a given layer. Is there any way to turn the label for a layer on or
> off dynamically? I didn't see anything obvious in the MapScript API.
Speaking from the world of PHP/Mapscript, with hopes that it's
applicable to your situation... Our solution is to set the label color
to something invalid, to suppress the rendering of labels, e.g.:
$class = $layer->getClassNyName('roads');
if (!$labels) {
$class->label->color->setRGB(-1,-1,-1);
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
