Multiple Levels-Of-Detail
Andrew Wooley
wooleys at GMAIL.COM
Wed May 30 13:50:43 EDT 2007
Dave,
I am not an OpenLayers expert by any means, but as of the 2.4 release (at
least), now with RC5, you can add a Mapserver Layer directly. This honors
the scale dependencies you have set up in your mapfile and you can have your
LOD.
Check out http://trac.openlayers.org/wiki/MappingYourData for a nice
tutorial. Make sure your watch the flash presentation. It makes it seem so
simple.
Andrew
On 5/30/07, Dave Weaver <dave.weaver at zen.co.uk> wrote:
> I'm playing around with OpenLayers in conjuntion with MapServer.
> What's the best way to have different levels of detail as I zoom in on my
> map?
> At the moment I've done it like this:
> My .map file has one layer per LOD, each using a MINSCALE/MAXSCALE
> directive
> to determine when it's visible.
> But that means I have multiple named layers, so the WMS request made by
> OpenLayers needs to request all layers.
> e.g: (mapfile)
> LAYER
> NAME lod1
> STATUS OFF
> TYPE RASTER
> PROJECTION
> "init=epsg:4326"
> END
> MINSCALE 75000000
> METADATA
> "wms_title" "lod1"
> "wms_onlineresource"
> "http://example.com/cgi-bin/mapserv?map=map/earth.map&"
> "wms_srs" "EPSG:4326 EPSG:54004"
> END
> TILEINDEX "lod1.shp"
> TILEITEM "location"
> END
> LAYER
> NAME lod2
> STATUS OFF
> TYPE RASTER
> PROJECTION
> "init=epsg:4326"
> END
> MAXSCALE 74999999
> MINSCALE 50000000
> METADATA
> "wms_title" "lod2"
> END
> TILEINDEX "lod2.shp"
> TILEITEM "location"
> END
> # ... etc ...
> then in the OpenLayers code:
> layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
> "http://example.com/cgi-bin/mapserv?map=map/earth2.map&",
> {layers:
> 'lod1,lod2,lod3,lod4,lod5'});
> Is there a better way to handle multiple LODs ?
> Many thanks,
> Dave.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070530/da5f7670/attachment.html
