hilite and zoom query in c#
sonj
sonj_you at YAHOO.CO.IN
Thu May 31 02:58:46 EDT 2007
For me also same problem. Is there any success at your end ?
I tryed this code
result = myLayer.queryByAttributes(map,"MAPNAME","[MAPNAME]=='" +
txtUser.Text + "'",0);
Error : Requested layer has no templates defined so is not queryable
lakku wrote:
> iam working with mapserver using C# mapscript
> iam displaying a map in imagebutton control
> now i want to zoom the features on the map related to query
> ie when user selects the layer and sub layer from dropdownlists and enters
> the value in the textbox then related features must be hilited and zoomed
> on the map
> i have wriiten a code for only hiliting the features but it is not working
> my code is :
> ddlLayersQuery is the dropdownlist (layers)
> ddlFieldsQuery is the dropdownlist (sublayers)
> txtValue is the textbox
> Dim image As imageObj
> Dim img As Byte()
> Dim ms As MemoryStream
> Dim bitmap, mapimage As Bitmap
> Dim str, st, st1 As String
> str = ddlLayersQuery.SelectedItem.ToString
> layer = map.getLayerByName(str)
> st = ddlFieldsQuery.SelectedItem.ToString
> Try
> layer.queryByAttributes(map, st, txtValue.Text, 1)
> Catch ex As Exception
> MsgBox(ex.Message)
> End Try
> Try
> image = map.drawQuery()
> 'image.save("mapimg.png", map)
> img = image.getBytes()
> Finally
> ms = New MemoryStream(img)
> mapimage = System.Drawing.Image.FromStream(ms)
> bitmap = mapimage
> bitmap.Save(Response.OutputStream,
> System.Drawing.Imaging.ImageFormat.Jpeg)
> End Try
> plz correct my code
View this message in context: http://www.nabble.com/hilite-and-zoom-query-in-c--tf3826164.html#a10888448
Sent from the Mapserver - User mailing list archive at Nabble.com.
