Mapserver support for OGR features
Tamas Szekeres szekerest at GMAIL.COM
Thu May 31 14:30:31 EDT 2007
Isabelle,
I think you should have a preconfigured matching symbol with the same
name of the pen style in your data source to render thick and pattern
lines. If you do not have a matching symbol with same the name
"default-circle" (if definied) is used to display the line.
For the layers of symbol types a symbol definition with the native
symbol name is looked up first, then the ogr-...generic name, and in
last resort try "default-marker" is used if provided by user.
Best regards,
Tamas
2007/5/31, Isabelle Kiener <isabelle.kiener at camptocamp.com>:
> Hi everybody,
> I try to display .TAB data with styleitem AUTO on Mapserver with OGR
> connection.It seems that Mapserver (version 4.8) ist not able to draw
> information such as symbol angle, hatch or line type defined by OGR feature
> respectively as a parameter, brush or pen.
> I did not find any information about this for the version 4.10. Is it
> planned to fix this in the next release of Mapserver?
> Thank you very much for your reply,
> Cheers,
> isabelle
