SLD not working on linux Fedora Core 5
Ruben Pardo
correosig at GMAIL.COM
Mon Nov 5 07:40:45 EST 2007
Thanks Tom,
when i do a GetCapabilities request on Linux i get
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
RemoteWFS="0"/>
on windows i get the same ...
RemoteWFS="0"/>
I've got differents ports because i've got two servers, an oc4j that
generate SLD's, and
a apache with mapserver. The SLDs are visible from the mapserver machine. I
also test with a SLD in
the same server, but i doesn't work
thanks
2007/11/5, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca>:
> Hi,
> A couple of initial ideas:
> - when you do a GetCapabilities request on Windows, do you get the
> following within the XML:
> RemoteWFS="0"/>
> - I notice that the SLD is on a host with a different port. Can the WMS
> box see the box of the SLD document (not sure if your example below is
> actual or has been modified for the list)
> ..Tom
> ________________________________
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ruben Pardo
> Sent: 05 November, 2007 5:56 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] SLD not working on linux Fedora
> Core 5
> Hi everybody,
> I'm using mapserver attaching SLD to a mapserver request. On
> windows the same request, with the same mapfile, with the same SLD
> works perfectly but it doesn't with my linux configuration.
> I read that the only thing that i need to get working SLD is
> OGR.
> works with windows.
> what could id do? where can i see what it happens?
> The request is:
> http://localhost/cgi-bin/mapserv?map=/usr/local/apache2/apps/mosaico_san
> dbox/htdocs/prbmosaico.map&service=WMS&request=GetMap&Layers=Municipios&
> version=1.1.1&SLD=http://localhost:8989/mosaico/jspx/sig/tmp/prb.xml
> <http://localhost/cgi-bin/mapserv?map=/usr/local/apache2/apps/mosaico_sa
> ndbox/htdocs/prbmosaico.map&service=WMS&request=GetMap&Layers=Municipios
> &version=1.1.1&SLD=http://localhost:8989/mosaico/jspx/sig/tmp/prb.xml>
> My linux mapserver version is:
> MapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS INPUT=TIFF INPUT=EPPL7 INPUT=SDE
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> The linux os is:
> 2.6.15-1.2054_FC5
> thanks a lot.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071105/df12b076/attachment.html
